Hello,
New user here. 4th day on bluefin…
I’m trying to add my printer, a Bother MFC-L3770CDW with drivers for Linux here, but no matter what I do I can’t seem to be able to print.
At first I downloaded the RPM package mfcl3770cdwpdrv-1.0.2-0.i386.rpm and installed it with rpm-ostree,. After reboot I could see the printer in the driver list, but it simply does not work (printing does nothing).
I then downloaded the tool linux-brprinter-installer-2.2.3-1 and this tried to install these packages
- mfcl3770cdwpdrv-1.0.2-0.i386.rpm
- brscan4-0.4.11-1.x86_64.rpm
- brscan-skey-0.3.2-0.x86_64.rpm
The first one I had installed myself, the other two are for scanning. The tool failed:
❯ sudo ./linux-brprinter-installer-2.2.3-1 MFC-L3770CDW
You are going to install following packages.
OK? [y/N] ->y
yum install glibc.i686
Note: This system is image (rpm-ostree) based.
Inactive requests:
adcli (already provided by adcli-0.9.2-3.fc39.x86_64)
sssd-ad (already provided by sssd-ad-2.9.4-1.fc39.x86_64)
Checking out tree 811f16d... done
Enabled rpm-md repositories: copr:copr.fedorainfracloud.org:ublue-os:akmods updates fedora rpmfusion-free-updates-testing rpmfusion-free-updates rpmfusion-free rpmfusion-nonfree-updates-testing rpmfusion-nonfree-updates rpmfusion-nonfree google-chrome rpmfusion-nonfree-nvidia-driver rpmfusion-nonfree-steam updates-archive
Importing rpm-md... done
rpm-md repo 'copr:copr.fedorainfracloud.org:ublue-os:akmods' (cached); generated: 2024-03-17T06:02:48Z solvables: 216
rpm-md repo 'updates' (cached); generated: 2024-04-16T02:20:46Z solvables: 25869
rpm-md repo 'fedora' (cached); generated: 2023-11-01T00:12:39Z solvables: 70825
rpm-md repo 'rpmfusion-free-updates-testing' (cached); generated: 2024-04-09T17:32:50Z solvables: 14
rpm-md repo 'rpmfusion-free-updates' (cached); generated: 2024-04-09T17:32:17Z solvables: 174
rpm-md repo 'rpmfusion-free' (cached); generated: 2023-11-04T16:49:08Z solvables: 445
rpm-md repo 'rpmfusion-nonfree-updates-testing' (cached); generated: 2024-04-09T18:02:39Z solvables: 2
rpm-md repo 'rpmfusion-nonfree-updates' (cached); generated: 2024-04-09T18:02:33Z solvables: 74
rpm-md repo 'rpmfusion-nonfree' (cached); generated: 2023-11-04T17:26:32Z solvables: 208
rpm-md repo 'google-chrome' (cached); generated: 2024-04-12T17:45:55Z solvables: 3
rpm-md repo 'rpmfusion-nonfree-nvidia-driver' (cached); generated: 2024-03-24T11:34:40Z solvables: 29
rpm-md repo 'rpmfusion-nonfree-steam' (cached); generated: 2024-03-24T13:27:05Z solvables: 2
rpm-md repo 'updates-archive' (cached); generated: 2024-04-16T02:49:58Z solvables: 42008
Installing 6 packages:
glibc-2.38-17.fc39.i686 (updates)
glibc-gconv-extra-2.38-17.fc39.i686 (updates)
libgcc-13.2.1-7.fc39.i686 (updates)
mfcl3770cdwpdrv-1.0.2-0.i386 (@commandline)
oddjob-0.34.7-9.fc39.x86_64 (fedora)
oddjob-mkhomedir-0.34.7-9.fc39.x86_64 (fedora)
Continue? [y/N] y
Inactive requests:
Checking out packages... done
Running pre scripts... done
Running post scripts... done
Running posttrans scripts... done
Writing rpmdb... done
Writing OSTree commit... done
Staging deployment... done
Freed: 93.9 MB (pkgcache branches: 0)
error: packages would be removed: 1, allow replacement to override
Notice the error message in the end (something about a package being removed?)
Anyway, the tool went on to log this:
Inactive requests:
Installing 7 packages:
libstdc++-13.2.1-7.fc39.i686 (updates)
Continue? [y/N] y
Inactive requests:
Will download: 1 package (955.0 kB)
Downloading from 'updates'... done
Importing packages... done
Freed: 94.5 MB (pkgcache branches: 0)
So it ended up with the same error twice, though it seems to have chose different extra packages (glic / libstdc++) between the two attempts. The tool then went on to log:
rpm -ihv --nodeps --replacefiles --replacepkgs mfcl3770cdwpdrv-1.0.2-0.i386.rpm
rpm-ostree: Note: This system is image (rpm-ostree) based.
rpm-ostree: Dropping privileges as `rpm` was executed with not "known safe" arguments.
rpm-ostree: You may invoke the real `rpm` binary in `/usr/libexec/rpm-ostree/wrapped/rpm`.
rpm-ostree: Continuing execution in 5 seconds.
error: open of mfcl3770cdwpdrv-1.0.2-0.i386.rpm failed: No such file or directory
###############################ls: cannot access '/usr/share/ppd/*.ppd': No such file or directory
ls: cannot access '/usr/share/cups/model/*.ppd': No such file or directory
semanage fcontext -a -t bin_t /opt/brother
restorecon -R /opt/brother
semanage fcontext -a -t cupsd_rw_etc_t /opt/brother/Printers/(.*/)?inf(/.*)?
restorecon -R /opt/brother/Printers
semanage fcontext -a -t bin_t /opt/brother/Printers/(.*/)?lpd(/.*)?
semanage fcontext -a -t bin_t /opt/brother/Printers/(.*/)?cupswrapper(/.*)?
restorecon -RFv /usr/lib/cups/filter
setsebool -P cups_execmem 1
Not sure what all these commands mean, but it seems it tried to use rpm directly?
Either way I have ended up with this status:
❯ rpm-ostree status
State: idle
Deployments:
ostree-image-signed:docker://ghcr.io/ublue-os/bluefin-dx:latest
Digest: sha256:d3eb7f17821b2aeab853724fd0e605e8b50029870883aec89f9b3f9dcee45e1a
Version: 39.20240416.0 (2024-04-16T21:37:18Z)
Diff: 1 removed, 4 added
LayeredPackages: 'libstdc++.i686' glibc.i686 oddjob-mkhomedir
LocalPackages: mfcl3770cdwpdrv-1.0.2-0.i386
● ostree-image-signed:docker://ghcr.io/ublue-os/bluefin-dx:latest
Digest: sha256:6343130fc93cbf463e2099d3c2262275f1101363998dd855d57bcae98d68c437
Version: 39.20240416.0 (2024-04-16T21:23:02Z)
LayeredPackages: oddjob-mkhomedir samba-common-tools
Unlocked: transient
Digest: sha256:ae199221fd22e3c38952bac292703f4282c3d7170eeb5db51399dc54e97ae353
Version: 39.20240416.0 (2024-04-16T16:52:59Z)
Ignore oddjob-mkhomedir as I installed that to join an AD domain and is completely unrelated to this, but as you can see the driver package is installed twice and I see:
❯ rpm -ql mfcl3770cdwpdrv-1.0.2-0.i386
/opt/brother/Printers/mfcl3770cdw/LICENSE_ENG.txt
/opt/brother/Printers/mfcl3770cdw/LICENSE_JPN.txt
/opt/brother/Printers/mfcl3770cdw/cupswrapper/brother_lpdwrapper_mfcl3770cdw
/opt/brother/Printers/mfcl3770cdw/cupswrapper/brother_mfcl3770cdw_printer_en.ppd
/opt/brother/Printers/mfcl3770cdw/cupswrapper/cupswrappermfcl3770cdw
/opt/brother/Printers/mfcl3770cdw/inf/ImagingArea
/opt/brother/Printers/mfcl3770cdw/inf/brmfcl3770cdwfunc
/opt/brother/Printers/mfcl3770cdw/inf/brmfcl3770cdwrc
/opt/brother/Printers/mfcl3770cdw/inf/lut/0600-c-TS_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/0600-c_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/0600-k-TS_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/0600-k_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/0600-m-TS_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/0600-m_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/0600-y-TS_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/0600-y_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/capt-c-TS_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/capt-c_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/capt-k-TS_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/capt-k_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/capt-m-TS_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/capt-m_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/capt-y-TS_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/lut/capt-y_cache17.bin
/opt/brother/Printers/mfcl3770cdw/inf/paperinfij2
/opt/brother/Printers/mfcl3770cdw/inf/setupPrintcapij
/opt/brother/Printers/mfcl3770cdw/lpd/brmfcl3770cdwfilter
/opt/brother/Printers/mfcl3770cdw/lpd/filter_mfcl3770cdw
/usr/bin/brprintconf_mfcl3770cdw
When I try to add the printer by enterint its IP address (in gnome settings printers) I get a vague error “Failed to add printer”.
If I try to print a test page I get:
Apr 17 01:11:47 myhost cupsd[6120]: Brother_MFC_L3770CDW_series: Unable to connect to brother1E8EDF7C.local:631: Temporary failure in name resolution
Apr 17 01:11:52 myhost cupsd[6120]: [Client 236] Returning IPP server-error-not-accepting-jobs for Create-Job (ipp://localhost/printers/Brother_MFC_L3770CDW_series) from localhost.
Apr 17 01:11:52 myhost cupsd[6120]: REQUEST localhost - - "POST /printers/Brother_MFC_L3770CDW_series HTTP/1.1" 200 393 Create-Job server-error-not-accepting-jobs
When I try to add the printer manually, I used the IP address and picked the JetDirect version (4th option in this list):
I tried all options from the list (here I pick the driverless one):
I see this in the log:
Apr 17 01:16:42 myhost cupsd[6120]: [CGI] Unable to create PPD file: Could not poll sufficient capability info from the printer (ipp://Brother%20MFC-L3770CDW%20series._ipp._tcp.local/, ipp://brother1E8EDF7C.local:631/ipp/print) via IPP!
Apr 17 01:16:42 myhost cupsd[6120]: copy_model: empty PPD file
Apr 17 01:16:42 myhost cupsd[6120]: [Client 253] Returning IPP server-error-internal-error for CUPS-Add-Modify-Printer (ipp://localhost/printers/Brother-MFC-L3770CDW) from localhost.
Apr 17 01:16:42 myhost cupsd[6120]: REQUEST localhost - root "POST /admin/ HTTP/1.1" 200 322 CUPS-Add-Modify-Printer server-error-internal-error
Apr 17 01:16:42 myhost gnome-control-c[25825]: cups-pk-helper: addition of printer Brother-MFC-L3770CDW failed: server-error-internal-error
Apr 17 01:16:43 myhost gnome-control-c[25825]: Installation of the new printer failed.
I’m quite lost as to what I should do next…
