Cannot start fedora-toolbox
I just installed bluefin-dx on my system and wanted to check if some extensions exist in Fedora’s repos so tried starting up a Fedora container with the <Ctrl><Alt>f shortcut.
I see the notifications saying that it’s downloading the image but after a while, it always bails out. I tried with ubuntu and it worked out just fine. Is there an error log somewhere around?
Instead I fired up a toolbox manually with toolbox create but I wonder why I can’t use the built-in function? :thinking:
systemctl status --user fedora-toolbox will let you know what’s going on with the service unit, usually if you don’t have one already set up then it takes a minute for it to download.
I guess the service has a 5m timeout? Unfortunetely my connections is VDSL and can’t make it within 5 minutes.
