Call for Testing: Bluefin GDX (Alpha)
Greetings programs!
While we were enabling Nvidia for Bluefin LTS we decided that instead of making an nvidia version for each of these that we would instead focus on just adding Nvidia to the developer experience(dx) image.
This is basically a Bluefin LTS image with nvidia and cuda enabled, so we’ve decided to make an AI/ML workstation out of this image. So we’re going to make bluefin-dx-nvidia:lts be it’s own SKU as Bluefin GDX to signify it’s specific use case.
ISO and image is available here:
Toss some feedback in this thread, thanks!
Is this the same as bluefin-dx-nvidia but based on CentOS instead of Fedora? Or are there more differences.
If it’s the former, could you explain the advantage of each? As I understand with Fedora (gts) nothing can go wrong because the base image is always clean and you can’t end up with a broken or unbootable OS, so what does the CentOS base add compared to Fedora?
Thank you
Is the EPEL repository automatically enabled in this, or do we need to enable it manually?
We use EPEL to make this, it’s off by default (we do this for most repos).
Also some more updates:
Hello from KubeCon London!
Thanks to @hanthor and our friends on the Ramalama team we were able to get local LLM workflows running on this monster System76 Astra ARM machine.
This is what btop looks like with 128 cores maxed out. (Note: Andrew Wafaa not included.) :smiley:
They even made a cute sign for us
Just yesterday, I tried to download and install the iso at Bluefin GDX (Beta) | Bluefin
Got a missing /images/pxeboot/vmlinuz error at boot.
Noticed that the iso is some 2GBs smaller compared to bluefin-dx-nvidia-open-stable.
Hence I think I’ll redownload and retry it once the iso-building issues are resolved.
Cool stuff btw :wink:
will aurora have this option also?
Its work in progess: GitHub - ublue-os/aurora-lts: Aurora Helium
Does the tag have to be “GDX”, btw? Since Bazzite also use GDX which is supposed to mean “Game Developer Xperience” there (as opposed to Bazzite DX which just adds stuff from Aurora DX to Bazzite as well) and is otherwise not LTS (not that Bazzite even has a GTS). Which make sense, but I don’t really care which is which, so long as it is different and is clear what GDX is supposed to stand for.
bluefin-cuda-lts
would be clear.
