Brother printer driver installation
I’m not an advanced linux user either.
When I moved from Windows to Bluefin, I had a similar issue with my printer (HL-L2460DW). The printer was recognized, but the printer options were bare mininum. For example, the 2460 is a duplex printer, but the system default didn’t show that option. Eventually, I downloaded the 2460 rpm from Brother. As a Windows user, I knew how to download a printer driver from Brother and double-click to install. That didn’t work with the Brother rpm package, since Bluefin is atomic. I first had to figure out what rpm-ostree was, then how to layer a package.
What I can’t figure out is, if we aren’t supposed to layer packages, how else are we supposed to get our printers working on Fedora atomic systems? This is going to be a problem for genuinely newbie users to the ublue ecosystem. Most people are going to have a printer they need to connect. If there is an alternative way, I need it spelled out step by step.
(As a side note, it wasn’t until reading this thread that I learned about the lpinfo -m command, then piping it to the grep command for a search on brother. My Brother printer wasn’t in the list either. I learned something new!)
Do you really need to install a driver? I see that your model supports wifi. I bought a Brother laser printer myself some months ago, a HL-L2465DW which seems similar to yours. I connected it to my wifi, and it works flawlessly in Ubuntu and Aurora, using IPP. No drivers. Easier than in Windows!
In KDE Plasma and in GNOME, when I try to add a printer, my Brother printer is automatically recognized on the network. Two choices are displayed, one with “(driverless)”. I chose the driverless.
Sorry it’s in French, but you should get the gist.
  • “Ajouter” is “Add”
  • “Imprimante” is “Printer”
  • “Sans pilote” is “driverless”
WIth the IPP driverless configuration, the duplex option for my DL-L2465DW is recognized. Here is the printer’s configuration, see 2-Sided Printing:
I also successfully used GNOME Document Scanner to scan pages (however it didn’t work in Ubuntu 24.04 LTS, but did in EndeavourOS) and SKanpage in Aurora.
Ah sorry, I missed that on first read. But why not use IPP, if it works? Of course, a wifi network is needed. In my case, as I have multiple computers at home, USB would be a hassle.
Generally its like that. layering is not recommended but unfortunately there are some situations that there is no other way.
For example most VPN clients won’t work as a flatpak/don’t have a working flatpak. There your options are either if the provider allows, import their wireguard/ovpn configs to networkmanager or layer their GUI package
The printer and scanner drivers for my model - HL-L2395DW - are here.
And if you feel ambitious, this page has links to the other drivers in the HL-L series, of which none are included in Aurora to date (Aurora lists many HL printers, but no HL-L printers. I assume that if the printers are listed that the drivers are also included).
Very well said tdb11235. You spelled out my thoughts exactly. I don’t know enough about the architecture of atomic systems to get a sense of if it is possible, but I hope that eventually this issue gets figured out. If it does, atomic systems would be gold for most people.
I use usb-ony connections as well, and don’t have a router - thus no wifi. So in my case, like ZacAttack, drivers are best.
Understood. But what is your sense down the road? Is it possible that eventually, there might be other/better solutions as atomic systems mature? Perhaps a stupid question, but again, I don’t know enough to know the answer.
Unfortunately, I failed to mention that both my computer and printer are connected to the home router via ethernet. So, wireless isn’t an option for me in this case, otherwise I would give it a try. Thankfully, I have a working solution for now.
Like others, I guess I will wait to see how printer installation evolves on Fedora atomic systems. Should be interesting to see what solution the Fedora atomic architects eventually implement to replace rpm-ostree layering.
Cayo’s repo mentions that
features will be provided as system extensions (systemd sysext) instead of via various images with tags (eg, minimal, hci and nvidia)
This was discussed on Fedora Discussion about adding NVIDIA drivers:
I understand that it wouldn’t work with kernel drivers? Are printer drivers kernel drivers (/modules, whatever)? I don’t know.
Timothée Ravier, the Fedora Atomic maintainer, linked a talk he did on sysext.
Timothée Ravier has a website for system extensions (experimental):
I’m certainly going to have a look at it, since I want to install k3s in Cayo. It seems to be it would be simpler to build a systext than building my own Cayo image.
Agreed. I do hope an easier, well-integrated (and ‘recommended’) method becomes possible at some point. Printing is a biggie for most folks using any OS.
Somewhat late response maybe.
But I fixed my printer driver with distrobox container and with cups another TCP port.
Then I Install any driver in the container and connect to the printer over the network.
Then I configure cups in the container. And then I configure the host cups to connect to the container cups.
This works when printers don’t support IPP.
I don’t like printer drivers on my host so this is a perfect workaround :wink:
