Brave starting slow
Hi,
On the Aurora , Brave Browser exhibits a significant startup delay of approximately 60 seconds when KDE Wallet is disabled. Enabling KDE Wallet resolves the delay, suggesting a dependency or interaction between Brave and KDE Wallet.
This is more of Brave issue and should be reported there.
Your right, I will do that.
edit:
I want to leave the ‘solution’ here, in case anyone comes looking:
Re-enable KDE Wallet Manager:
Go to: System Settings > KDE Wallet
Check “Enable the KDE wallet subsystem”
Create an existing wallet with no passwords stored.
Set it to auto-close and not open at startup.
This satisfies dependent services without storing sensitive data.
