First, let me say that Bazzite is great. I also own a Steam Deck, which I often connect to my TV, and I wanted to replicate the same behavior on my mini PC. Everything works fine except for Bluetooth.
My main problems were:
Audio stuttering when using Bluetooth headphones.
DualSense gamepad not working correctly (loss of control during games).
No wake-up from sleep mode using the gamepad.
My mini PC is a low-end Chinese model with a fairly basic BIOS. I wish I could disable Wi-Fi to reduce interference. I’m completely new to Fedora, being more used to Debian. ChatGPT was heavily used during troubleshooting. I’m also glad I installed SSH, as it allowed me to control Bazzite from my main PC and not from my couch :-).
Hardware & Setup
Mini-PC: TS-12C with AMD Ryzen AI 9 HX 370 @ 5.16 GHz, 24 cores
OS: Bazzite (Fedora Atomic-based) –
bazzite-deck:stable, kernel6.16.4-108.bazzite.fc42.x86_64 -
Internal Bluetooth: Intel AX210 (
8087:0032) -
External Bluetooth Dongles Tested:
ASUS USB-BT500 (Realtek RTL8761BU chipset) → mostly functional
Ugreen dongle (Realtek as well) → failed
Devices tested:
Sony WH-1000XM4 headset
TaoTronics SoundSurge 90 headset
Sony DualSense controller (PS5)
Issues Observed
Low audio quality & stuttering
Headsets were stuck in HSP/HFP “headset” profile (low quality, telephone-like audio).
Even when switched, audio often reverted from A2DP high-quality profile back to headset.
Severe stuttering on both internal and external adapters.
Controller problems
DualSense connected but showed poor range (unstable beyond ~1 meter).
Could not wake the system from suspend via Bluetooth, while USB keyboard worked fine.
Interference & distance issues
Mini-PC placement and nearby devices created interference.
Required USB extension cable for the dongle at first.
Troubleshooting Steps Taken
Checked firmware availability under
/lib/firmware/rtl_bt/(firmware for RTL8761BU was present and loaded correctly). -
Monitored kernel logs (
dmesg,btmon) confirming firmware loads and reporting TX power levels. -
Verified profiles using
pactl list cards→ saw onlyheadset-head-unitactive at first. also seen on kde mixer -
Experimented with systemd service to auto-select the ASUS dongle.
Tried both adapters (AX210 & ASUS BT500): both showed similar issues initially.
Workarounds & Fixes
Interference reduced: moved mini-PC and disabled Wi-Fi/BT on a nearby system → significant improvement.
ASUS dongle on extension cable: stabilized audio and controller range.
Profile fix: after shutting down and unpluging the the pc for 30 seconds/rebooting, A2DP profile became available and worked stably. (why ?)
Wake from suspend:
AX210 theoretically supports USB wakeup (
/sys/bus/usb/devices/.../power/wakeup). -
Set to
enabled, works but the other problem remains
Ugreen dongle → discarded as it never worked properly.
Internal AX210 finally disabled to avoid conflicts it was always default BT:
Created
/etc/modprobe.d/blacklist-intel-bt.confwithblacklist btintel. -
After reboot, only ASUS BT500 remains active (
bluetoothctl listshows BC:FC:E7…).
Current Status
Audio: A2DP high-quality profile works fine, no stuttering.
Controller: Works over Bluetooth, but range is limited works fine with an extension cable.
Suspend: Controller cannot wake the PC via Bluetooth via external dongle .
Final Setup: Running with ASUS BT500 only, Intel AX210 Bluetooth disabled.
One path we haven’t fully explored is changing the Bluetooth radio power via the OS. i’m not even sure it’s possible.
Posting this could help others struggling with poor Bluetooth quality / stuttering / controller issues on Bazzite, since the combination of interference management, firmware confirmation, and forcing a single adapter solved most issues.
