Hey,
Put bluefin-lts on a new drive to replace my old one, and copied my user directory to the /var/home on the new drive, running the whole thing in a VM first to see how it goes
bluefin-lts appears to include distrobox, sure enough, but my scripts call for zenity and xhost, and neither one seem to be included. Looks like at least xhost is included in other releases, like bluefin, bazzite, etc. if I’m reading these forum threads correctly.
Is this by error or design?
Edit: I might be able to replace zenity with dialog (zenity does not work when installed via brew) but xhost is not a brew package, and installing via unpacked rpm in /usr/local would be a real PITA (lots of .so dependency packages)
Would this be more suitable as a bug report? Thanks
Edit: Noticing views, but no replies - is basically just nobody using bluefin-lts?
I personally hate btrfs because it feels like it introduces a geometric FS-usage proportional response latency to the system. Also why I stopped installing ZFS for root devices way long ago (on anything but Solaris-derivs). I always install Fedora to xfs thinvols, or any other distro, for that matter… e.g. Ubuntu or Debian using debootstrap : https://unixgreybeard.org/2024/08/12/the-miracle-of-debootstrap-installing-ubuntu-to-thin-lvm-in-a-very-archlinux-like-way/)
If there’s any way to install a bootc image on a different filesystem than it was containerized as, would love to know (I’m fantasizing, right?)
