Another roll up release, this is likely the last one before the major bluefin:gts update, which is on track for October 29th, following Fedora. There will be the usual weekly build this week but there will be an additional build on that Tuesday to get everything released and aligned.
If you are on a daily build you’ll see the cosmetic changes on your next update.
3.7.0 (2024-10-24)
Features
- apply theming updates & enable xwayland scaling (#1813) (87d8c97)
- ci: Build stable weekly on the same day as gts (#1803) (4b199ab)
- ci: turn on F41 builds (#1801) (7b049bd)
- made Documentation, Community and System Update icons themeable (#1819) (342d01c)
- move fish fastfetch config for user customizability (#1820) (21514e7)
- new autumn wallpaper (#1794) (ff123d2)
- reduce install size by compressing images (#1806) (3f7e580)
- ublue-rollback-helper - add stable-daily to targets (#1797) (01e25a8)
Bug Fixes
- background looks washed out during fade (#1818) (e9d5272)
- don’t attempt to pull zfs on beta (#1802) (e4d9322)
- dx: cockpit-bridge replaces cockpit-pcp (#1828) (b1fbcaa)
- fix cryfs error on bluefin-gts (#1799) (71a9232)
- restore missing wallpapers in aurora (#1807) (49c8291)
