This discussion is open for improving Bazzite based on your experience.
Make sure to describe if these apply to all of images, the desktop AMD/Intel images, the desktop Nvidia images, or the Steam Deck / HTPC / Handheld PC images.
Noted feedback from the survey and old thread
- Project moves too fast and it’s difficult to keep up with all of the changes to Bazzite even with the newsletters and other documentation.
- Concerns with too many images which comes across as daunting to the user when they have to choose one in the installer.
- HDR support.
- Most of the other
just
commands should be in the Bazzite Portal or some other GUI. - Nix/Home Manager/Fleek GUI so users can be build their
$HOME
environment easily. - A warning built into Bazzite for major changes especially since updates on the desktop images are automatic.
- Handheld PCs that are NOT the Steam Deck need better support if possible.
- Bazzite Portal option to use only use the dGPU in hardware with hybrid graphics to prevent games from using integrated graphics.
- Bazzite Portal redesign: “Back” button and a generic “Next/Skip” button or some way to get to a specific page without having to uncheck things you already installed for post-installation configuration.
If you would like to make any of these changes yourself by submitting a pull request to the project, then you can follow the contributor’s guide for guidelines on the project.
