I’m relatively new to Linux (dabbled with arch on my Laptop and had a Steam Deck for close to a year), but after installing whenever i get to the desktop one of my monitors starts bootlooping and the taskbar vanishes,it constantly makes the non-stroking monitor switch between the primary display and being secondary. Unplugging the screen that’s having issues is not helping.Both of my monitors are samsungs, one fhd and one qhd (qhd is the one having issues). this did not happen during installation, while i’m in the login screen or in windows (dual-boot).
Anybody have or had a similar issue or know a fix?
Please give us hardware information and the output of rpm-ostree status.
Hardware: CPU AMD Ryzen 5700 X3D
Motherboard MSI B550M PRO-VDH WIFI
32 GB G.Skill Trident Z RGB
Drive is a Samsung PM9A1
GPU AsROCK Phantom RX 6800
rpm-ostree status output:
State: idle
Deployments:
● ostree-image-signed:docker://ghcr.io/ublue-os/bazzite:stable
Digest: sha256:72ae13c334ed9db3fc0eee5707d94e9d7d669fd413ea90b49043bdf1e55d51f7
Version: 41.20250106.3 (2025-01-07T04:23:44Z)
LayeredPackages: coolercontrol lact liquidctl
LayeredPackages: coolercontrol liquidctl
Can you confirm that the monitor doesn’t have issues on another OS?
Can confirm, worked flawlessly before I transistioned into the dual-boot setup on windows and it works flawlessly on windows now.
Could LACT be the issue? I don’t see how liquidctl or coolercontrol could be an issue, unless it caused a temperature issue.
Other than that, maybe it’s the HDMI? IIRC Linux as a whole still have problems with HDMI 2.1 right?
After fiddling around for a while i’ve found that swapping the cable types of my monitor seems to have fixed the issue. Changing from DP to HDMI seems to have stabilized it, while the other one on the same DP cable is still issue free. Very weird, but if it works, it works. At least it rules out the GPU ports themselves being an issue.
Nevermind my previous comment, issue reappeared after restart. Swapping cables only fixes it until shutdown apparently.
Hi
I hope you already find a correction for this issue.
I had this issue too with dual screen on Display port but with old NVIDIA GPU.
It was resolved by flashing the GPU bios.
Hope this help.
edit 2 : this is only working if I let at least one monitor with the input select as " auto"
for some reason with input select as “displayport” the issue is coming back after reboot or sleep with both monitor connected physically with DP cables.
I had the same issue, disabling the Adaptive Sync fixed it for me (set it to never).
