Bazzite freezes with eGPU
I got Bazzite Gnome installed on my Legion Go. When I connect an eGPU and I’m clicking on anything or try to drag a windows, the computer completely freezes, only a hard reboot solves it.
I’m using Gnome because it has a virtual keyboard I can use with a mouse on external display.
The funny thing is, my eGPU was working perfectly on the KDE version of the same OS…
Are you using all-ways-egpu script for setting up egpu?
I didn’t have to use anything on KDE so I have no idea what to do
According to my experience KDE has better hotplug support but using all-ways-egpu script with method 2+3 or method 1 is delivering better performance under KDE. Regarding Gnome itself I was never able to get egpu running without using that script (last time I checked was 2023 honestly). In case you are interested you can check it out here and here. You need to use the immutable filesystem setup method but this breaks method 1 (method 2+3 is fine honestly). In case you really want to use method 1 you need to add a policy file as explained on github but this is overwritten on every bazzite update. You can layer a selfcreated package. I can explain you how if needed.
I requested to add an ujust command here on bazzite’s github but it’s still to discussed.
@Zetarancio Are you running into hard locks from sleep/wake? I have a Legion Go and I am experiencing this where my device is able to sleep but freezes on wake.
My device doesn’t turn on but the eGPU does.
Sleep undee egpu does not work correctly under any combination of circustance/device/linux distro I owned or tried :partying_face:
That’s my understanding as well. I will create a DRM bug as it’s likely the driver causing the lock ups :(.
BTW, are you also experiencing similar issues with sleep/wake where the device hard locks on wake?
Unfortunately I currently use my ayaneo geek 1s and it has its own issue with sleep (as detailed in the wiki) which is solvable but not permanent untill ayaneo drops (eventually) a bios fix. So I can’t really tell for sure if the hard lock is related to the egpu, but:
-when fix is applied it freezes on resume
-my old and we’ll supported HP 1030g3 experience the same issue when waking up from sleep with egpu connected
  • I briefly owned a Lenovo yoga a few years ago and it did the same
-I briefly owned a Lenovo yoga a few years ago and it did the same
@Zetarancio I narrowed this down due to an upstream kernel bug with the Thunderbolt drivers.
See:
@Zetarancio I may have a fix! You need to create a system unit to unbind the amdgpu drivers before sleep. My eGPU is now able to sleep/resume without hangups.
I outlined the rough steps here: Hard lock with External GPU on sleep/wake cycle (#3706) · Issues · drm / amd · GitLab
Nice. This is a way to fix many sleep issue, I will test it. But will this make the whole desktop environment crash on resume when run from eGPU?
Nope, the desktop environment successfully recovers and the eGPU is detected and loaded on wake/resume.
The only downside is that anything that uses the GPU will crash on resume, so you will need to close games before suspend.
Are you running games on Optimus/prime and desktop environment on the internal GPU or you load desktop environment on the GPU and launch games from there?
I have a AMD iGPU and an external AMD 7600M GPU. I only play game within gamescope and I run games with that I can manually select the GPU.
Hi! I’m a noob when it comes to this stuff but I have a Legion Go and Onexgpu and I’d love to be able to implement your fix so I can finally use this egpu within bazzite and make it go to sleep properly. Can you walk me through the steps to do so?
