Bazzite Fatal Error
I get a fatal error when installing that says:
Failed to install flatpaks:flatpak-error-quark: Aborted due to failure (While pulling runtime/org.winehq.Wine.gecko/x86_64/stable-23.08 from remote Anaconda: Writing content object: Invalid compressed data) (4)
recommand to redownload
Tried that, failed again.
It’s a shot in the dark, but if you re-create the installer USB and start with a fresh Bazzite install, are you still seeing the same issue? If so, I wonder if it could’ve been the way the image was burned to the USB.
