Bazzite doesn’t notify about updates anymore
That’s my problem. If I start the update manually with system update in the application menu, it does update… But it’s not proposing any updates to me anymore.
Maybe there is no updates? How long since you last had an update?
Have you turned off suggest updates?
I think last friday. Anyway I remember that everyday or almost, the apps where updated. Like Chrome, Emulators, etc. I dunno, to me it seems something stuck.
Can You please guide me checking this out? Thanks in advance.
Now that you mention it, I also didn’t have updates in several days, but when I start the update manually, there are things to be updated. I didn’t notice it until your post.
What Desktop environment are you using? Gnome or KDE?
I am using KDE as DE.
Edit: just opened Bazaar and there were 15 updates but I didn’t get any notification as I used to.
I use KDE over GNOME actually
Exactly, that’s my problem. I suppose also the system updates are stuck
Under system settings > software update you can set it you want to manual update and if you want notifications or not.
Yes. I haven’t changed that setting, it’s set to notify me daily. But it doesn’t.
Leaving my current status here in case someone is wondering:
rpm-ostree status
State: idle
AutomaticUpdates: check; rpm-ostreed-automatic.timer: inactive
Deployments:
● ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-nvidia:stable
                   Digest: sha256:bf68d04b0c2aca3092339d618fa265ae15ad7225acca9a4483661cd357e8a913
                  Version: 42.20250804 (2025-08-04T05:35:54Z)
                   Digest: sha256:861be288e480ac5fb1efeedd3c6ee7e9a44370d6fe3dadcf91ef9823ee1e755f
                  Version: 42.20250731 (2025-07-31T20:26:15Z)
Isn’t that the newest stable?
Should be. Like I said above, I updated manually. The reason for this thread is, that the notification isn’t working anymore.
Doesnt that mean that the cron timer is off….?
No, automatic updates are off, notifications are on (in my example).
Since the title of this topic is a bit misleading, maybe @antodena could modify it? Something like “Bazzite doesn’t notify about updates anymore”? This could clarify the issue and hopefully we get some answers then?
It seems I’m not able to change the title. Would You help me doing that?
Changed the topic for you guys
