Hi team,
The nvidia 560 driver have been released, and according to this topic, integrated in the bazzite-nvidia images soon.
I’m far from an expert, but they should fix a few issues with Gamescope + NVIDIA
AFAIK there is no bazzite-deck-nvidia image out of the box and one would need to create his own image through a mix and match of the bazzite-deck Containerfile and bazzite-nvidia Containerfile.
Could someone double-check if the steps are right ?
Use the current bazzite-nvidia Containerfile
Changes :
- FROM bazzite-deck AS bazzite-deck-nvidia (instead of FROM bazzite)
- ROCm removal stays untouched as it’s specifically meant for AMD GPUs
plasma-workspace-x11install needs to be removed as it would conflict with Gamescope- NVIDIA Drive install stays untouched
- In build_iso.yml, add bazzite-deck-nvidia to the list of ISOs to be built
Feel free to tell me if this is redundant, I’m happy to help if someone else is working on this.
Edit :
Is there a way to build the images locally instead of on GitHub ? I doubt these images are buildable within the ghcr.io free tier (500MB storage)
1 Build the container file > 2 find the script that packages the iso and then run that ?
