Bazzite (and Fedora) installer bootloop
Hi!
I’m looking for help in installing Bazzite. The problem is that I can’t even boot to the installer screen. When I select the option to install Bazzite, the Bazzite logo gets stuck in a loop for about a minute. After that, it just reboots straight to Windows or to Grub if I choose to prioritise the USB in BIOS. Running the installer in safe graphics mode has no effect. I’ve tried disabling Secure Boot and Fast Boot as some guides suggest, but nothing changed. Then I tried using a different USB with a Fedora Silverblue .ISO and rebashing it to Bazzite, as the website suggests in case of problems. This also failed. However, some command lines are displayed when trying to run the live session. So I know that regardless of whether I enable or disable Secure Boot and Safe Graphics Mode, the final screen is the same. I have attached a screenshot of this to the post.
My PC’s specifications are:
Motherboard: Gigabyte B550M DS3H AC rev. 1.4
CPU: AMD Ryzen 5 5500
GPU: Nvidia Geforce RTX 4060
RAM 32GB DDR4
Storage: 2 x 1tb. M.2 PCIe NVMe disk
