bazzite + ally x + rpcs3
Strange issue with RPCS3 on Bazzite
Seems I can’t add games in folder format, the emulator doesn’t find anything bootable
Exactly, it doesn’t find anything, not even in the usdir
steam deck ok
I’ve upped your permissions so you can just paste in the screenshots.
Just had to tinker with this problem to get it working on bazzite a couple days ago. Did you right click on the iso and “open with Ark” prior to putting it in the folder? This seems to be the equivalent of “mounting” the iso on windows and how I was able to get rpcs3 to finally load it.
Also, if your using emulation station (rather than running the emulator from steam directly) - add .ps3 to the end of the folder name containing the iso, and it will now pop up there.
