Auto update stopped working?
I am also never getting auto update :frowning: maybe because I have set up hibernation on all my devices. So I rarely reboot. And if I do reboot, the device will suspend/hibernate WITHIN 1 hour, which means the updater won’t be triggered (since it waits 1 hour after reboot.. which makes little sense no?)
Bluefin 41 + hibernation set up:
● rpm-ostreed-automatic.timer - rpm-ostree Automatic Update Trigger
     Loaded: loaded (/usr/lib/systemd/system/rpm-ostreed-automatic.timer; enabled; preset: disabled)
    Drop-In: /usr/lib/systemd/system/rpm-ostreed-automatic.timer.d
             └─override.conf
     Active: active (waiting) since Thu 2025-04-17 08:43:09 CEST; 1 day 2h ago
 Invocation: f52f65c14f2e47b1af44cc8ecb80f5f6
    Trigger: Sat 2025-04-19 04:06:28 CEST; 16h left
   Triggers: ● rpm-ostreed-automatic.service
       Docs: man:rpm-ostree(1)
             man:rpm-ostreed.conf(5)
Apr 17 08:43:09 bluefin systemd[1]: Started rpm-ostreed-automatic.timer - rpm-ostree Automatic Update Trigger.
lines 1-12/12 (END)
On Fedora 42 images we will move to uupd, our new background updater.
So I would suggest you wait for F42 based images (already available in latest ) and test with it, You might need to enable it if you update/rebase and disable the old rpm-ostreed-timer things.
If you still have issues, recommend to file them at the uupd repo on github: GitHub - ublue-os/uupd
I just ran the System Update app, it ran (downloaded a bunch of stuff and did some things).
Then it just disappears.
I ran it again, this time it went so fast and disappeared, I couldn’t read anything.
So I just rebooted. To my surprise, when I check Settings > System, I am still on 41. So I would say manual update also doesn’t work..
EDIT: Now I tried ujust update:
❯ ujust update
Pulling manifest: ostree-image-signed:docker://ghcr.io/ublue-os/bluefin:stable
No upgrade available.
Looking for updates…
Info: (pinned) runtime org.gnome.Platform branch 45 is end-of-life, with reason:
   The GNOME 45 runtime is no longer supported as of September 18, 2024. Please ask your application developer to migrate to a supported platform.
Info: runtime org.freedesktop.Platform branch 22.08 is end-of-life, with reason:
   org.freedesktop.Platform 22.08 is no longer receiving fixes and security updates. Please update to a supported runtime version.
Info: applications using this runtime:
   no.mifi.losslesscut
Info: runtime org.freedesktop.Platform.VAAPI.Intel branch 22.08 is end-of-life, with reason:
Info: applications using this extension:
   no.mifi.losslesscut
Info: runtime org.freedesktop.Platform.GL.default branch 22.08-extra is end-of-life, with reason:
   no.mifi.losslesscut
Info: runtime org.freedesktop.Platform.GL.default branch 22.08 is end-of-life, with reason:
   no.mifi.losslesscut
Nothing to do.
~ took 3s
Looks like LosslessCut (flatpak) still uses some outdated library. Other than that, nothing to do..
You’re supposed to be on F41 you’re on bluefin:stable. Everything is working as intended.
Oh stupid me, I thought Bluefin stable was available already with F42. Sorry!
I also see GNOME 45 pinned. Not sure why.
Is there a reason this is pinned? In my case, No.
I did:
flatpak pin --remove runtime/org.gnome.Platform/x86_64/45
flatpak pin --remove runtime/org.gnome.Platform.Locale/x86_64/45
That did it for me.
Of course, if you have no.mifi.losslesscut installed you will need to uninstall that first.
