Introduction
So on windows, the majority of people use Blish HUD and love it (i do too!).
However Blish HUD has some issues on Linux which makes it not so appealing to use.
The good thing though is that the most common thing people care about from Blish actually works in Linux, that being markers! You just have to use TaimiHUD from Raidcore Nexus or Burrito instead for loading the markers which often are based on TaCO.
For ArcDPS we will just use ArcDPS as it is already fully working in Linux
while Raidcore Nexus handles all the loading and managing of the addons.
For any other addons we will use Raidcore Nexus which will also chainload Burrito if you use that instead of TaimiHUD. This is an addon loader which works inside the game through an overlay and also has some of the addons from blish (or somilar ones), one example being the Radial menu for mounts in blish called “Mounts & More”, in Raidcore Nexus they have “Radial Menu” instead. A lot of the useful things are still in Raidcore.
Now to tie all of this together we will use
- Scopebuddy (pre-installed on Bazzite) to notify about and update ArcDPS before anything launches and also modify the gw2 launch options in my case as i have an ArenaNet account for the game instead of a Steam account
- Raidcore Nexus to let us use ArcDPS and other addons along with TaimiHUD or Burrito for markers
If you are migrating from the old Gw2AddonManager setup, please follow these migration steps first!
- Delete or rename your
addonsfolder (it will conflict with the one from Raidcore Nexus and crash the game) - Delete the
Gw2AddonManagerdirectory we made in the Guild Wars 2 folder - Delete the
d3d11.dllanddxgi.dllfiles from the Guild Wars 2 folder - Delete any
d3d11.dll,dxgi.dll,d3dcompiler_43.dllandd3dcompiler_47.dllfiles frombin64andbin64/cef
Remember to update the following files with the ones from the new guide below!
- Update the arcdps manager script at
~/.config/scopebuddy/scripts/dl-arcdps - Update the scopebuddy config at
~/.config/scopebuddy/AppID/1284210.conf
Installation
NOTE: For simplicity in writing the guide, it will assume you want ArcDPS, Markers & other addons, the file structure will reflect this.
Increasing compatibility with some addons (this may no longer be needed, mentioned just in-case)
- Install Guild Wars 2 through Steam (even if you use an ArenaNet account!) and open the launcher once and close it to generate the prefix for proton.
- Run Protontricks (if it complains about not having access to your steam library locations, fix that with the command it gives you and re-launch Protontricks)
- Select Guild Wars 2, click OK
- Make sure
Select the default wineprefixis selected and click OK - Click
Install a Windows DLL or component - Select
d3dcompiler_43,d3dcompiler_47andd3d11_43and click OK and wait (if you get an error about not using a socket, ignore it)
Configure ScopeBuddy (optional QoL)
NOTE: ScopeBuddy is used for updating ArcDPS before anything runs, and frankly i am tired of manually updating or removing it whenever it breaks the game. ArcDPS breaks frequently with updates so having an update check before launch is beneficial (especially if you have to temporarily delete the .dll to launch the game until the addon gets updated)
- Make the config file in
~/.config/scopebuddy/AppID/1284210.conf - Add the below text to the config file and save
# Guild Wars 2
# Remove the line below to disable MangoHUD
export MANGOHUD=1
# Tell scopebuddy to not run the game inside nested gamescope
SCB_NOSCOPE=1
# Get the game directory from %command%
cmdARGS=$(echo $command | awk -F '" "' '{ print NF }')
for ((i = 1; i <= cmdARGS; i++))
do
GAMEDIR=$(echo $command | awk -F '" "' -v i="$i" '{ print $i }')
# If we found "waitforexitandrun"
if [ "$GAMEDIR" == "waitforexitandrun" ]; then
# Increase i by 1 and grab the game directory then exit the loop early
i=$(($i+1))
GAMEDIR=$(echo $command | awk -F '" "' -v i="$i" '{ print $i }' | sed 's/\/Gw2-64.exe//')
break
fi
done
# Add launch arguments to Guild Wars 2
# "-provider Portal" lets you login with an ArenaNet account instead of using Steam Login
# If you use Steam to login, please remove "-provider Portal"
command+=" -provider Portal -maploadinfo"
# Uncomment and use this instead if you want to launch burrito automatically with the game (files must be inside a "burrito" folder in the "addons" folder in Guild Wars 2
# Make sure you uncomment this AFTER all addons have been setup
#command+=" -provider Portal -maploadinfo & sleep 10 && env -u LD_PRELOAD \"$GAMEDIR/addons/burrito/burrito.x86_64\""
# Run script to update arcdps if needed
bash "$SCB_CONFIGDIR/scripts/dl-arcdps" "$GAMEDIR"
# Allow modifying the game files (not sure if this is still needed)
export PRESSURE_VESSEL_FILESYSTEMS_RW="$(echo $GAMEDIR | sed 's/\s/\\ /g')"
Create the script file inside ~/.config/scopebuddy/scripts/dl-arcdps and put in the following
#!/bin/bash
GW2_DIR=$1
ARCDPS_DLL="$GW2_DIR/addons/ArcDPS.dll"
NEWMD5SUM=$(wget -qO- https://www.deltaconnected.com/arcdps/x64/d3d11.dll.md5sum | awk '{print $1}')
MD5SUM=$(md5sum "$ARCDPS_DLL" 2>/dev/null | awk '{print $1}')
MANAGED_FILE="$GW2_DIR/.arcdps_managed"
MANAGED_ARCDPS=0
if [ -f "$MANAGED_FILE" ]; then
MANAGED_ARCDPS=1
fi
if [ "$MD5SUM" != "$NEWMD5SUM" ] || [ -f "$MANAGED_FILE" ]; then
dialog=$(yad --form --separator="," \
--title="ArcDPS Manager" \
--text="Update ArcDPS?\nNew MD5:\t$NEWMD5SUM\nOld MD5:\t$MD5SUM" \
--field="Manage ArcDPS on every launch":CHK $MANAGED_ARCDPS \
--button="Remove ArcDPS":6 \
--button="Update ArcDPS":4 \
--button="Launch GW2":2
status=$?
IFS=, read -r MANAGED_ARCDPS <<< "$dialog"
case $status in
4)
wget -O "$ARCDPS_DLL" https://www.deltaconnected.com/arcdps/x64/d3d11.dll ;;
6)
rm "$ARCDPS_DLL" ;;
esac
if [ "$MANAGED_ARCDPS" == "TRUE" ] && [ ! -f "$MANAGED_FILE" ]; then
touch "$MANAGED_FILE"
elif [ "$MANAGED_ARCDPS" == "FALSE" ] && [ -f "$MANAGED_FILE" ]; then
rm "$MANAGED_FILE"
fi
fi
This will create a nice manager for ArcDPS to update it whenever there is an update (or show it before launching Guild Wars 2 each time). The default is for this to only show when there is an update.
To make this dialog appear on every launch, add the file .arcdps_managed into your Guild Wars 2 folder or enable the checkbox before pressing any of the buttons.
NOTE: Every button will close the dialog, do the action you asked and then continue launching Guild Wars 2
Installing the Addons
Download Raidcore Nexus, we want the dll directly
Open Steam and right click on Guild Wars 2, click Properties
If you configured ScopeBuddy, set the Launch Options to
scb -- %command%so the game will launch through scopebuddy in the future. If you are not using scopebuddy and just want to play with an ArenaNet account then set the Launch Options to-provider Portal -
Then navigate to Installed Files and click
Browse -
Place the
d3d11.dllfrom Raidcore Nexus here. It should look like this
Launch Guild Wars 2
If you configured ScopeBuddy, you will get a prompt to update ArcDPS, select if you want to show “ArcDPS Manager” on every launch if you want to, then click
Launch GW2for now (going forward after ArcDPS is installed, you will pressUpdate ArcDPSif the MD5 checksums do not match). -
Once in-game, press
CTRL+Oto open Raidcore Nexus, then navigate toLibrary -
Install ArcDPS
Note: ArcDPS or any addon you choose to install, will not vanish from the Library list until you navigate away from the Library tab after it is installed. -
Go back to the
Installedtab andLoadArcDPS, then continue installing the Pathing and Markers addon of your choice. -
You can now download and use TaimiHUD inside Raidcore Nexus which is now the recommended way to get pathing and markers. You can download marker packs from the Data Sources tab inside TaimiHUD. If you rather use Burrito for pathing and markers, please continue reading the next section.
Use Burrito for pathing and markers instead of TaimiHUD
NOTE: We recommend using TaimiHUD over Burrito now due to better integration and easier management and access to marker packs.
Download Burrito extract the files into
addons/burritoand open theburrito_linkfolder and renamed3d11.dlltod3d11_chainload.dlland copy it to the Guild Wars 2 game folder so that it is next to the Raidcore Nexus d3d11.dll.NOTE: If importing TaCO packs does not work for you, use Burrito-next the pre-release version of burrito, as of writing there is a chance importing TaCO marker packs fails on Burrito version 1.0.0 for some people.
Download the TaCO marker packs you want (i personally use tekkit all in one, choose to just download the Marker Pack)
Launch Guild Wars 2
Launch Burrito after Guild Wars 2 has launched (otherwise it might not constantly appear over Guild Wars 2 when playing!)
If you have multiple monitors, Burrito might have launched on the wrong monitor (thank you wayland!), hold down the WIN button and left click and drag the Burrito icon to the correct monitor and place it along the top bar in Guild Wars 2
The Burrito icon and the Nexus icon will overlap! Open the Nexus window with CTRL+O and go to settings and change Location to
Customand change the offset (or be lazy and set Location toUnder)
Click the Burrito icon and import any TaCO marker packs you have downloaded (importing them will temporarily freeze the interface, just grab a drink and wait).
While the Burrito menu is open, the game ignores any input and your screen will have a RED border!
Congratulations you now have ArcDPS (Settings opened with ALT+SHIFT+T), Raidcore Nexus (settings opened with CTRL+O) and Markers added to Guild Wars 2! ![]()
I know this will not give you all the awesomeness of BlishHUD, but i hope this will provide you with enough of the creature comforts
You can find Burrito settings and data files inside ~/.local/share/godot/app_userdata/Burrito/
Update 2025.06.08: Added a commented out line to the scopebuddy appid config for gw2 to launch burrito with the game.
Update 2025.09.13: If you want to automatically move burrito to the correct monitor automatically on KDE then you can use these window rules in the system settings, just change the Position width to the correct one (you can grab the value by moving burrito to the correct location then use Detect Window Properties button and click on the burrito icon)
Update 2026.01.25: Recommend TaimiHUD in Raidcore Nexus over Burrito.
