I’m running Bazzite 39 - Steam Deck & HTPC Edition
on a Ryzen 5700G with a RX 6600. It is a fresh install.
I would like to see the power usage of the CPU and GPU when gaming. I would also like to see the CPU cooler RPM.
I was hopping to install Bazzite and MongoHUD would appear on every game without further configuration.
What do I need to do in order for it to happen?
in gamescope session (gamemode) press CTRL+2 (on controller this is GUIDE+A, however on xinput devices it is press GUIDE and release it, then press A immediately after you release GUIDE, this is a driver thing) when ingame and just enable the performance overlay from there.
If you want to add/remove things from the different presets, just follow a guide on youtube on how to edit the mangohud presets in steamos 3.5, it will work the same in bazzite.
That you very much.
For further reference the MangoHud - Config file is located at
~/.config/MangoHud
