I apologize if this post is inappropriate. I have had problems with the Zoom client flatpak for awhile. It does not show my schedule. Frustrating to say the least.
So, although it may be controversial, i installed the Gear Lever flatpak and added the Zoom appimage I downloaded to its menu. Problem solved. The Zoom icon appeared in my App Grid. And the appimage works perfectly.
I don’t user Zoom, so can’t confirm the issue, but flatpak system in Blufin is nothing special. If you have flatpak issue, it is most probably the issue in other distros too. Probably you will get way more help at Zoom bug tracker.
