Gnome-software does not show flathub repository in bluefin-dx
When I open gnome-software, I find there is no flathub apps as shown in the screenshot.
But flatpak remotes does show flathub system.
Btw. I am using remote desktop in Windows to connect to the bluefin machine. I’m not sure if this is relevant to the issue.
Any help is greatly appreciated.
Which image are you on?
I did a quick QEMU install with bluefin-latest image and software center shows the flathub repo.
If you search some app in the software center, does it still show up?
I am using bluefin-dx:stable. I search geary for example in the software center, it does not show up. But in command line flatpak search geary it does show up.
Ensure you’re quit out of gnome-software and then try flatpak update --appstream.
I use pkill gome-software to quit and ps aux | grep gnome-software to make sure of it. I then try flatpak update --appstream and then log out. But the problem is still there.
You can use the app Warehouse to add flatpak repo’s.
I’m not sure why, but as described in my question, I’ve noticed that this situation only occurs when connected remotely. When using Bluefin in person, in front of the machine, it displays normally.
I noticed the same, Flatpaks do not show in Software Centre when using remote desktop, when using from the proxmox console they show ok. Flatpaks install from the command line and warehouse remotely.
