Winapps installation errors
Attempting to install Winapps to my Bazzite install. Following dannymate’s tutorial here: Winapps in Bazzite Portal which is great but upon going to the install I am getting the following errors. I am still wet behind the ears here and have zero clue as to what I am looking at or looking for. Can anyone point me in a direction to go because everywhere I look/go I get no where.
File “/home/George/.local/bin/podman-compose”, line 8, in
sys.exit(main())
File “/home/George/.local/lib/python3.13/site-packages/podman_compose.py”, line 3711, in main
asyncio.run(async_main())
File “/usr/lib64/python3.13/asyncio/runners.py”, line 194, in run
return runner.run(main)
File “/usr/lib64/python3.13/asyncio/runners.py”, line 118, in run
return self._loop.run_until_complete(task)
File “/usr/lib64/python3.13/asyncio/base_events.py”, line 720, in run_until_complete
return future.result()
File “/home/George/.local/lib/python3.13/site-packages/podman_compose.py”, line 3707, in async_main
await podman_compose.run()
File “/home/George/.local/lib/python3.13/site-packages/podman_compose.py”, line 1859, in run
self._parse_compose_file()
File “/home/George/.local/lib/python3.13/site-packages/podman_compose.py”, line 1955, in _parse_compose_file
content = yaml.safe_load(f)
File “/usr/lib64/python3.13/site-packages/yaml/init.py”, line 125, in safe_load
return load(stream, SafeLoader)
File “/usr/lib64/python3.13/site-packages/yaml/init.py”, line 81, in load
return loader.get_single_data()
File “/usr/lib64/python3.13/site-packages/yaml/constructor.py”, line 49, in get_single_data
node = self.get_single_node()
File “/usr/lib64/python3.13/site-packages/yaml/composer.py”, line 36, in get_single_node
document = self.compose_document()
File “/usr/lib64/python3.13/site-packages/yaml/composer.py”, line 55, in compose_document
node = self.compose_node(None, None)
File “/usr/lib64/python3.13/site-packages/yaml/composer.py”, line 84, in compose_node
node = self.compose_mapping_node(anchor)
File “/usr/lib64/python3.13/site-packages/yaml/composer.py”, line 127, in compose_mapping_node
while not self.check_event(MappingEndEvent):
File “/usr/lib64/python3.13/site-packages/yaml/parser.py”, line 98, in check_event
self.current_event = self.state()
File “/usr/lib64/python3.13/site-packages/yaml/parser.py”, line 438, in parse_block_mapping_key
raise ParserError(“while parsing a block mapping”, self.marks[-1],
“expected , but found %r” % token.id, token.start_mark)
yaml.parser.ParserError: while parsing a block mapping
in “./compose.yaml”, line 3, column 1Traceback (most recent call last):
sys.exit(main())
expected , but found ‘’
in “./compose.yaml”, line 26, column 5
It is possible that compose.yaml is somehow mangled. If you copy-pasted it, make sure that item indentation is consistent. Also sometimes quotes get copied incorrectly into some similar-looking UTF-8 character.
You could try pasting your compose.yaml contents into some online YAML syntax validator (quick google found for example this: https://yamlchecker.com/) to see if it passes validation. You can also check YAML files locally using yamllint available via brew.
It’s yelling about you missing commas in the compose.yaml file. At the end of lines 3 & 26 I think.
