Why am I being censored on GitHub Bluefin discussions?
Title. I can’t report bugs or even comment on already posted topics. Is my only option AI to get some help?
why do you think that?
Because whenever I make a comment or post and go to the URL of the topic in another browser my post/comment isn’t available to be seen.
I’m running ostree-image-signed:docker://ghcr.io/ublue-os/bluefin-nvidia:stable
with nvidia 1660. Should I be on the open version or the regular stable version with the last update being Oct 24th? Because a few weeks ago when I tried switching to the open version I had some issues with extensions and apps not running right.
               Digest: sha256:23a6ec0dc3a2f887d30eef4a34ac6a14c2c7644b09ddcd0f7a4a6ef09b938a60
              Version: 42.20251024.1 (2025-10-24T12:10:52Z)
      LayeredPackages: proton-vpn-gnome-desktop
        LocalPackages: protonvpn-stable-release-1.0.3-1.noarch veracrypt-1.26.20-1.x86_64
May have been something to do with my Nvidia drivers - I didn’t spend to much time, I just rolled it back.
yes the -nvidia images are eol, you need to rebase to the nvidia-open image.
Not sure what is happening with the github stuff, we only have a spam prevention there so hard to say what is the issue.
So I ran rpm-ostree reset. Then ujust rebase-helper and re-based to the non-nvidia image, it worked fine (aside from not having nvidia). From there, ran ujust rebase-helper and switched to the open nvidia version.
Now, nvidia works fine, but simple things like Text editor, calculator, extension manager won’t even open. Any recommendation?
Deployments:
● ostree-image-signed:docker://ghcr.io/ublue-os/bluefin-nvidia-open:stable
Digest: sha256:19347abf89ac47f7724ae1a71a1386964808fbb5d2969341ce6f1590dac99fb0
Version: 43.20251126.1 (2025-11-26T15:32:04Z)
ostree-image-signed:docker://ghcr.io/ublue-os/bluefin:stable
Digest: sha256:bf4050ca890979463189f2ede677c048d82ac97e75e30fb60297b3fba396fe20
Version: 43.20251126.1 (2025-11-26T15:27:46Z)
Nevermind. Suddenly everything just started working out of the blue.
