When I tried installing Rust on distrobox, it installed itself on ~/.cargo/bin/rustc? How to fix?
Why I think it’s unintended behavior is because when I installed PHP & Composer inside another container, it installed them on /usr/bin/composer and /usr/bin/composer (not on my host /usr, I ls’d and grep’d to check) respectively and cannot be accessed from the host machine.
But when I try to install Rust, distrobox installed it on ~/.cargo/bin/rustc (my host ~), and even after I deleted the Rust container it stayed on ~/.cargo/bin/rustc. Not to mention Rust is accessible from my host machine.
What can I do to prevent this? I know distrobox create --home ~/Documents/rust-box -n rust-box exists, but distroboxes are supposed to be disposable and I dunno if giving a box its own home directory can be considered disposable. Plus I don’t know if it will delete the stuff in its given directory after deletion.
Or is this supposed to be intended behavior?
This is totally fine.
Distrobox is a convenience script that mounts your home directory transparently, there will be use cases where you don’t want this.
The box is still disposable you’re just keeping its data separate.
You can try adjusting the cargo dir config by changing the associated env vars inside of your distrobox. To aid with things like that I usually set the hostname to the name of the distrobox like this:
alias box='distrobox enter -a --env=HOSTNAME=fedora41-python-dx fedora41-python-dx -- bash'
With that done it is straightforward to put conditional logic in the .bashrc scripts based on HOSTNAME.
In your case,
if  [ "$HOSTNAME" = "rust-box" ];then
# set the CARGO_HOME, etc. env vars as you would like them.
fi
Here is the env var ref for cargo:
But, if it were me, I would just let my host HOME dir be mounted and accept the defaults. That is what I do for 99.999% of the programming tool chains I use.
Pros:
  • shared across distrboxen - I often have project specific containers with customized sets of tool chains based on that project’s needs (installed via dnf / apt / apk / curl or equiv.)
  • centralized config - I setup things like env vars one time on my host and get the benefit of that in all distrboxen / devcontainers;
  • I have a repo in a git server on my LAN called local-config where I manage my ~/.bashrc, ~/.local/.bash.d/ scripts, ~/.config/, etc.;
  • if I need to override something in one container that is easy using the approach I mentioned above
Con:
  • if a tool chain cannot isolate packages for each tool chain version some how, I need to accommodate that by forcing it to use /usr/local or some other prefix in the container outside of my home dir. But, I have only needed to do that once. I immediately challenged myself to find a different - more modern - tech stack. :wink:
And then when I am done with that project, I tear down the distrobox because it is no longer needed. I have automation to create / re-create them so, in 6 months when I need to pick it up again, I review the script that creates it, update it if necessary and run it. In a few minutes I am back where I was.
I created this project to explain what those scripts look like and why.
