Maliit keyboard not launching
Installed Bazzite for the first time last night but can’t get the Maliit Virtual Keyboard showing. It is vital for my workflows. Anyone come across this?
Fedora KDE Plasma typically comes with 2 virtual keyboards by default. Does the other work for you? Is it possible to use it in your workflow? If not, which specific functionality of Maliit do you need?
BTW, any chance Maliit is appearing on a different display, possibly even one that is no longer connected or is turned off? What about on a different workspace due to an application window rule or the like?
No chance of another display unfortunately. Im using the desktop version. I noticed virtual keyboard is not an item under accessibility.
