Unit hhd.service could not be found
Hello
I'm a new Linux user. I've decided to install Bazzite OS.
I'm still working through the difficulties of switching from Windows,
but this one has me stumped.
I have a RedmiBook Pro 16 2023 laptop with an AMD 7840HS processor.
It doesn't have a discrete graphics card,
so to reduce noise and improve battery life,
I decided to use Handheld Daemon. And it didn't work.
Tried installing from Git.
curl -L https://github.com/hhd-dev/hhd/raw/master/install.sh | bash
Reboot, check and again Unit hhd.service could not be found.
Tried downloading it from the Fedora repository. That didn't help.
P.S. Sorry for the poor translation.
Looking at this script, it seems like the service you would want is called hhd_local.
New users can only add one screenshot per message. Therefore, the reply must be in three messages.
After reboot
It is hhd_local not hhd-local
systemctl status hhd_local@username
replace username with your local username.
So it worked, but I wasn’t checking it correctly. It’s unclear why it wasn’t enabled by default.
Thanks for the help
hhd is being replaced in bazzite. More information on that here:
