Is there anyway to install ujust pacakge manager into something like arch linux?
It is not a package manager, it’s a program that runs predefined scripts / commands.
The ujust command is nothing else than just with specific parameters. You can see that using:
cat /usr/bin/ujust
Installing it on Arch is as easy as:
sudo pacman -S just
