I couldn’t find this info anywhere, but I’m sure I’m missing it somewhere. How do I turn on the dashboard/taskbar permanently like on bluefin? I’d prefer not have to cycle through apps using ctrl-tab and just click on the app in the dashboard.
You need to set the dash to dock extension not to autohide in its settings.
and how do I get to the dash settings? I’m not seeing any dash options in settings or able to search for dash in applications. Nor in appearance or display, I’m just not seeing anywhere to configure dash. Thanks!
Search for the Extensions app on the drawer. From there you will be able to find settings for extensions, including Dash to Dock.
I see what the problem is… me! I thought this was a built in feature you were talking about, once I installed the dash to dock extension, I can set it to always on. Thanks!
