I think I have found a solution to this issue that seems to have worked (so far…) in my case.
After a quite a bit of googling, I came across a conversation on the Fedora Reddit about someone having a similar issue in (not-atomic) Fedora. They were using several Flatpaks on their system and using Flatseal to manage them.
For some reason, the person realized they had inadvertently toggled off the options “X11 windowing system” and “Wayland windowing system” globally in Flatseal. After toggling them back on, they no longer had wake from suspend problems.
I took a look at mine and, sure enough, both those options were toggled off. I don’t recall doing that, but I probably did it when playing around in the options trying to get Lutris to display in dark mode. I say that because it seems that both of those toggle switches should be on in Flatseal by default (I’m talking about the global options in Flatseal here, not the individual application settings).
I have turned them both back on… and so far so good! It’s been a few days now and I have had no trouble waking from suspend since I re-enabled those two toggle switches in Flatseal.
I will freely admit that I’m not entirely sure why having those toggles in the off position would cause my monitor to refuse to respond when waking from sleep, but… I’ll take it! My best guess it is that I tend to suspend my machine with a few GUI apps open, stuff like Firefox or Steam, etc. Since all GUI apps in Bluefin/Aurora are Flatpaks, maybe having the windowing system toggles turned off with those applications open was what was causing the problem?
Either way, I thought I would leave a note in this thread for anyone out there who experiences something similar on the off chance that it might be helpful. Especially since I can’t seem to find the Reddit thread again where I found the solution in the first place…
EDIT - I wanted to correct myself on something! If you are on Wayland, only toggle on the “Wayland windowing system” option in Flatseal. Leave the X11 one off.
I turned them both back on, seemed to be doing alright, but started having intermittent problems again. After some more google-fu, I found the reddit conversation that sent me down this path and realized the user with this suggestion had actually only mentioned the Wayland option.
You can read that reddit thread here - https://www.reddit.com/r/Fedora/comments/12jbny1/black_screen_after_waking_up_from_suspend/
