Experiencing problems after waking up my PC from sleep mode
Hello, I recently switched from Windows to Bluefin after discovering it. However, just a few days in, I’m already facing some issues.
When my PC goes into sleep mode after being idle for X minutes, it doesn’t display anything on the monitor when I try to wake it up by pressing the power button. The PC itself powers on, but the screen remains blank. I also tried manually turning the monitor off and back on, but that didn’t make a difference.
Both my GPU & CPU is AMD
Update:
I think I fixed the issue by turning off Bluetooth in the settings. Then, I clicked on Suspend to test it, and I was able to wake the computer up as normal.
For people who is facing the same, someone sent my this link:
Workaround while the bug is being fixed
Just tried it by turning off bluetooth in gnome settings and suspend worked.
Good call.
