Syntax-Error: bash_completion.d/enosys
Hey guys!
Thank you, for this wonderful OS! At first all the cloud-stuff let me feel fear, but after a while, it turned into huge respect for you all!
When i started the (default) terminal this morning in bluefin, i got this error message:
bash: /home/linuxbrew/.linuxbrew/etc/bash_completion.d/enosys: Zeile 19: Syntaxfehler beim unerwarteten Symbol »)«
bash: /home/linuxbrew/.linuxbrew/etc/bash_completion.d/enosys: Zeile 19: `		'-d'|'--dump')'
there’s a small syntax error in the enosys file:
_waitpid_module()
	local cur prev OPTS
	COMPREPLY=()
	cur="${COMP_WORDS[COMP_CWORD]}"
	prev="${COMP_WORDS[COMP_CWORD-1]}"
	case $prev in
		'-s'|'--syscall')
			return 0
		'-i'|'--ioctl')
			return 0
		'-l'|'--list')
the opening parenthesis are not there. Is it okay for you guys, if i open a pull request on github, or is this something, you can do in between your non existent time?
Greetings and big thx!
It’s a case switch so there won’t be an opening parans.
What is missing is after thr -m option is the double ; closing that case. You can add the fix yourself.
This has been reported to the upstream project and should hopefully propagate to brew quickly.
Thank you, for your fast and great help!
Thanks, that help me too !
