I’m currently using Fedora 42 on an ASUS Laptop and I’m experienced with several other KDE Plasma Distros on varios other Laptops. I currently own a Micro$oft Surface Pro 7+ that I’m able to install and use just about any Distro, but getting this 2-in-1 to work in Tablet mode with Touch screen and virtual on screen Keyboard is very problematic. I downloaded and installed Aurora in hopes of getting things to work on my Micro$oft Surface Device. As I’ve read, Aurora supports Surface devices, but I could use some direction or help with this. Thank you
You will need the hwe image to makte it somewhat work.
Although, just to note, we will be dropping the asus and surface images when F43 lands in the fall.
New here, similar question. Since the post wasn’t closed, I figured it was acceptable to continue this thread.
Just got an old surface. Tried to follow the linux-surface-kernel guide to get it running on Aurora, based on the Fedora Silverblue instructions. No luck.
➜ rpm-ostree override replace ./*.rpm --remove kernel-core --remove kernel-modules --remove kernel-modules-extra --remove libwacom --remove libwacom-data --install kernel-surface --install iptsd --install libwacom-surface --install libwacom-surface-data
Checking out tree ada148a... done
Enabled rpm-md repositories: updates fedora terra-extras terra linux-surface updates-archive
Importing rpm-md... done
rpm-md repo 'updates' (cached); generated: 2025-08-18T01:51:41Z solvables: 22129
rpm-md repo 'fedora' (cached); generated: 2025-04-09T11:06:59Z solvables: 76879
rpm-md repo 'terra-extras' (cached); generated: 2025-08-18T02:06:28Z solvables: 351
rpm-md repo 'terra' (cached); generated: 2025-08-19T00:40:13Z solvables: 2870
rpm-md repo 'linux-surface' (cached); generated: 2025-06-26T00:51:31Z solvables: 38
rpm-md repo 'updates-archive' (cached); generated: 2025-08-19T00:53:13Z solvables: 35802
Will download: 9 packages (172.5 MB)
Downloading from 'linux-surface'... done
Downloading from 'updates-archive'... done
Importing packages... done
Relabeling... done
Applying 6 overrides and 10 overlays
Processing packages... done
Running systemd-sysusers... done
Running pre scripts... done
Running post scripts... done
Running posttrans scripts... done
error: Running %posttrans for kernel-surface-core: bwrap(/bin/sh): Child process exited with code 1; run `journalctl -t 'rpm-ostree(kernel-surface-core.posttrans)'` for more information
I’d take suggestions. My next step was going to be to try and build with the surface kernel already in. It sounds like that might work, but if I understand correctly, even this will be shortlived, and doomed to fail after the autumn. So maybe I should just look for a different distro now?
Addendum: The Silverblue kernel installation instructions also fail on Silverblue, but Fedora Desktop works fine. This likely indicates the problem is in the Silverblue instructions, and something has changed to make those no longer valid. I’ll be going to that project to see if I can learn more.
Please update your findings if possible, thanks.
I gave up on this, and went first to a custom Aurora build that integrated the Surface Kernel, then to Bazzite once they reintroduced full support for Surface devices.
OK! Great, I suppose? Somehow never appeared during my research and my Surface is still on CachyOS because of the noob confusion.
Thanks a lot for the reply, much appreciated.
*another noob bites the dust and 10s of open tabs and such classic mess, apparently Dosu recommended Bazzite already yesterday
Dosu also suggested building a custom image with finpilot, interesting, might as well try that!
