Steam not launching after ujust update 18.08.25
After last ujust update yesterday evening 18.08.2025, when i had time to log in to computer system became unstable.
First wife called me, about my comp’s screen flickering - it had rebooted and in Steam gamemode as it’s usual, display was flickering partially with green artifacts, moving mouse - everything went “as usual” screen at place , switched to desktop , noticing some kind flicker , while desktop was loading.
Network sharing worked (as router is in RMA, i have share connection thru my Intel NUC).
EDIT: If to switch from Desktop to Gamemode - i can for example launch few windows games i have installed , like Lord of The Rings Online and World of Tank Blitz, other games will not start. In Desktop i cant launch any game.
EDIT 2:
ujust fix-steam-rest - no command like this.
EDIT 3: in wayland screen if to leave mouse cursor anywhere on screen , lower part starts to flicker with steam overall desktop split in to three quadrates - upper part statick , lower part has 2 parts of screen flickering.
Lets make clear :
Im using bazzite-nvidia-deck (#42) with external NVIDIA 1660 on eGPU dock thru M.2 slot.
Before update everything worked without any issues. To me looks like update from NVIDIA 557 driver to 580 is causing issues.
Along wlan driver issue some kind is introduced… it works and shares connection but in dmesg it gives license warnings …
Anyone could help me with suggestions beside re-install (I do not feel very motivated re-downloading some 100 Gb of games + setting em up , particulary “Blizzard.net Launcher” part )
System specs and some logs i managed to reproduce follow:
@bazzite
bazzite-deck-nvidia:stable Bazzite (FROM Fedora Atomic)
Linux 6.15.9-106.bazzite.fc42.x86_64
uptime: 18 mins
NUC7i3BNK (J31188-308)
Intel(R) Core™ i3-7100U (4) @ 2.40 GHz
 NVIDIA GeForce GTX 1660 SUPER [Discrete]
5.83 GiB / 31.28 GiB (19%)
158.20 GiB / 475.35 GiB (33%) - btrfs [Read-only]
1920x1080 @ 60 Hz (as 1536x864) in 32" [External]
KDE Plasma 6.4.4
KWin (Wayland)
bash 5.2.37
Ptyxis 48.5
2930 (rpm), 51 (flatpak)
dmesg:
[ 24.379417] snd_hda_intel 0000:00:1f.3: device 8086:2068 is on the power_save denylist, forcing power_save to 0
[ 24.559473] Bluetooth: hci0: Firmware revision 0.1 build 19 week 44 2021
[ 24.562530] Bluetooth: hci0: Reading supported features failed (-16)
[ 24.562537] Bluetooth: hci0: Error reading debug features
[ 24.562544] Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
[ 24.822443] Intel(R) Wireless WiFi driver for Linux
[ 24.824422] iwlwifi 0000:3a:00.0: enabling device (0000 → 0002)
[ 24.848279] iwlwifi 0000:3a:00.0: Detected crf-id 0xbadcafe, cnv-id 0x10 wfpm id 0x80000000
[ 24.851006] iwlwifi 0000:3a:00.0: PCI dev 24fd/9010, rev=0x230, rfid=0xd55555d5
[ 24.851019] iwlwifi 0000:3a:00.0: Detected Intel(R) Dual Band Wireless AC 8265
[ 24.852924] NET: Registered PF_QIPCRTR protocol family
[ 25.001030] iwlwifi 0000:3a:00.0: loaded firmware version 36.c8e8e144.0 8265-36.ucode op_mode iwlmvm
[ 25.029266] intel_tcc_cooling: Programmable TCC Offset detected
[ 25.172879] nvidia-gpu 0000:3c:00.3: i2c timeout error e0000000
[ 25.172889] ucsi_ccg 5-0008: i2c_transfer failed -110
[ 25.172894] ucsi_ccg 5-0008: ucsi_ccg_init failed - -110
[ 25.172909] ucsi_ccg 5-0008: probe with driver ucsi_ccg failed with error -110
[ 25.695660] intel_rapl_common: Found RAPL domain package
[ 25.695666] intel_rapl_common: Found RAPL domain core
[ 25.695669] intel_rapl_common: Found RAPL domain dram
[ 25.695671] intel_rapl_common: Found RAPL domain psys
[ 25.969988] iwlwifi 0000:3a:00.0: base HW address: a0:af:bd:f0:f4:01, OTP minor version: 0x4
[ 26.052992] ieee80211 phy0: Selected rate control algorithm ‘iwl-mvm-rs’
[ 26.710292] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 26.710299] Bluetooth: BNEP filters: protocol multicast
[ 26.710305] Bluetooth: BNEP socket layer initialized
[ 26.713642] Bluetooth: MGMT ver 1.23
[ 27.005025] wl: module license ‘MIXED/Proprietary’ taints kernel.
[ 27.005032] Disabling lock debugging due to kernel taint
[ 27.005035] wl: module license taints kernel.
[ 27.126818] You are using the Broadcom STA wireless driver, which is not maintained and is incompatible with Linux kernel security mitigations. It is heavily recommended to replace the hardware and remove the driver. Proceed at your own risk!
[ 27.126824] ------------[ cut here ]------------
[ 27.126826] Unpatched return thunk in use. This should not happen!
[ 27.126831] WARNING: CPU: 3 PID: 802 at arch/x86/kernel/cpu/bugs.c:3351 __warn_thunk+0x2a/0x40
[ 27.126864] Modules linked in: nf_conntrack_netbios_ns nf_conntrack_broadcast wl(POE+) nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat bnep nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 snd_sof_pci_intel_skl snd_sof_intel_hda_generic soundwire_intel snd_sof_intel_hda_sdw_bpt snd_sof_intel_hda_common snd_soc_hdac_hda snd_sof_intel_hda_mlink snd_sof_intel_hda soundwire_cadence nf_tables snd_sof_pci snd_sof_xtensa_dsp snd_sof iwlmvm snd_sof_utils snd_soc_acpi_intel_match snd_soc_acpi_intel_sdca_quirks soundwire_generic_allocation snd_soc_acpi crc8 soundwire_bus intel_rapl_msr snd_soc_sdca mac80211 intel_rapl_common snd_soc_avs intel_uncore_frequency intel_uncore_frequency_common intel_tcc_cooling libarc4 x86_pkg_temp_thermal intel_powerclamp coretemp snd_soc_hda_codec qrtr snd_hda_ext_core iwlwifi kvm_intel snd_soc_core snd_compress snd_hda_codec_realtek ac97_bus btusb snd_hda_codec_generic snd_pcm_dmaengine snd_hda_codec_hdmi
[ 27.126937] snd_hda_scodec_component snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec ucsi_ccg typec_ucsi btrtl typec ee1004 btintel mei_hdcp mei_pxp snd_hda_core btbcm kvm btmtk snd_hwdep cfg80211 sunrpc snd_seq rapl intel_cstate snd_seq_device bluetooth snd_pcm intel_uncore intel_wmi_thunderbolt pcspkr snd_timer wmi_bmof i2c_i801 e1000e snd i2c_smbus soundcore i2c_nvidia_gpu mei_me binfmt_misc mei rfkill intel_pch_thermal vfat fat intel_xhci_usb_role_switch intel_pmc_core pmt_telemetry joydev pmt_class acpi_pad intel_vsec tcp_bbr vhba(OE) ryzen_smu(OE) hid_nintendo hid_playstation ff_memless led_class_multicolor loop nfnetlink lz4 zram lz4hc_compress lz4_compress overlay erofs netfs rtsx_pci_sdmmc mmc_core polyval_clmulni polyval_generic ghash_clmulni_intel sha512_ssse3 uas sha256_ssse3 usb_storage sha1_ssse3 rtsx_pci nvidia_uvm(OE) nvidia_drm(OE) nvidia_modeset(OE) nvidia(OE) amdgpu amdxcp gpu_sched drm_panel_backlight_quirks drm_ttm_helper drm_exec drm_suballoc_helper i915 drm_buddy ttm video wmi
[ 27.127038] i2c_algo_bit drm_display_helper cec vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio iommufd uhid pkcs8_key_parser ntsync kvmfr(OE) gcadapter_oc(OE) fuse i2c_dev
[ 27.127056] Unloaded tainted modules: nvidia_peermem(OE):1 nct6687(OE):2
[ 27.127064] CPU: 3 UID: 0 PID: 802 Comm: (udev-worker) Tainted: P OE 6.15.9-106.bazzite.fc42.x86_64 #1 PREEMPT(full)
[ 27.127071] Tainted: [P]=PROPRIETARY_MODULE, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 27.127073] Hardware name: Intel Corporation NUC7i3BNK/NUC7i3BNB, BIOS BNKBL357.86A.0088.2022.0125.1102 01/25/2022
[ 27.127076] RIP: 0010:__warn_thunk+0x2a/0x40
[ 27.127081] Code: 66 0f 1f 00 0f 1f 44 00 00 80 3d 5c 75 8c 02 00 74 05 c3 cc cc cc cc 48 c7 c7 58 0b 63 9a c6 05 47 75 8c 02 01 e8 66 d6 08 00 <0f> 0b c3 cc cc cc cc 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00
[ 27.127085] RSP: 0018:ffffcf9fc0a3f8e8 EFLAGS: 00010246
[ 27.127088] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000027
[ 27.127091] RDX: ffff8ac39ed9cb88 RSI: 0000000000000001 RDI: ffff8ac39ed9cb80
[ 27.127093] RBP: ffffcf9fc0a3f938 R08: 0000000000000000 R09: ffffcf9fc0a3f790
[ 27.127095] R10: ffffffff9b13c168 R11: 00000000ffffdfff R12: ffffffffc4f15bc5
[ 27.127098] R13: ffffffffc46b2010 R14: 00007eff50c52965 R15: 0000000000000000
[ 27.127100] FS: 00007eff50ce5040(0000) GS:ffff8ac402ded000(0000) knlGS:0000000000000000
[ 27.127103] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 27.127105] CR2: 00007f2ff82d3050 CR3: 00000001168a4002 CR4: 00000000003726f0
[ 27.127108] Call Trace:
[ 27.127111]
[ 27.127113] warn_thunk_thunk+0x16/0x30
[ 27.127126] getvar+0x20/0x70 [wl]
[ 27.127208] ? __UNIQUE_ID_vermagic475+0x305ffa20c77a/0x305ffa20c77a [wl]
[ 27.127271] wl_module_init+0x23/0xb0 [wl]
[ 27.127330] ? do_one_initcall+0x58/0x300
[ 27.127339] ? do_init_module+0x84/0x260
[ 27.127345] ? init_module_from_file+0x8a/0xe0
[ 27.127354] ? idempotent_init_module+0x114/0x310
[ 27.127361] ? __x64_sys_finit_module+0x67/0xc0
[ 27.127366] ? do_syscall_64+0x7b/0x160
[ 27.127371] ? audit_reset_context+0x298/0x300
[ 27.127378] ? switch_fpu_return+0x4e/0xd0
[ 27.127382] ? syscall_exit_to_user_mode+0x1d5/0x210
[ 27.127386] ? do_syscall_64+0x87/0x160
[ 27.127390] ? ima_file_check+0x5b/0x80
[ 27.127396] ? mntput_no_expire+0x4b/0x280
[ 27.127402] ? terminate_walk+0xef/0x100
[ 27.127406] ? __seccomp_filter+0x41/0x4e0
[ 27.127412] ? path_openat+0x134/0x2c0
[ 27.127417] ? audit_reset_context+0x298/0x300
[ 27.127422] ? syscall_exit_to_user_mode_prepare+0x17e/0x1f0
[ 27.127428] ? syscall_exit_to_user_mode+0x10/0x210
[ 27.127431] ? do_syscall_64+0x87/0x160
[ 27.127437] ? mntput_no_expire+0x4b/0x280
[ 27.127441] ? audit_reset_context+0x298/0x300
[ 27.127446] ? syscall_exit_to_user_mode_prepare+0x17e/0x1f0
[ 27.127451] ? syscall_exit_to_user_mode+0x10/0x210
[ 27.127455] ? do_syscall_64+0x87/0x160
[ 27.127459] ? do_syscall_64+0x87/0x160
[ 27.127462] ? exc_page_fault+0x7e/0x1a0
[ 27.127465] ? entry_SYSCALL_64_after_hwframe+0x76/0x7e
[ 27.127472]
[ 27.127474] —[ end trace 0000000000000000 ]—
[ 27.166182] iwlwifi 0000:3a:00.0 wlp58s0: renamed from wlan0
[ 27.997902] iwlwifi 0000:3a:00.0: Registered PHC clock: iwlwifi-PTP, with index: 1
[ 38.883606] evdi: [I] Initialising logging on level 4
[ 38.883612] evdi: [I] Atomic driver: yes
[ 40.574608] Bluetooth: RFCOMM TTY layer initialized
[ 40.574619] Bluetooth: RFCOMM socket layer initialized
[ 40.574630] Bluetooth: RFCOMM ver 1.11
[ 46.919298] e1000e 0000:00:1f.6 eno1: NIC Link is Up 100 Mbps Full Duplex, Flow Control: None
[ 106.583637] nvidia-gpu 0000:3c:00.3: i2c timeout error e0000000
[ 107.584142] nvidia-gpu 0000:3c:00.3: i2c timeout error e0000000
[ 108.584647] nvidia-gpu 0000:3c:00.3: i2c timeout error f0000100
[ 109.585031] nvidia-gpu 0000:3c:00.3: i2c timeout error e0000000
[ 109.585037] nvidia-gpu 0000:3c:00.3: i2c stop failed -110
[ 117.206172] NVRM: API mismatch: the client ‘steam’ (pid 6042)
NVRM: has the version 575.64.05, but this kernel module has
NVRM: the version 580.76.05. Please make sure that this
NVRM: kernel module and all NVIDIA driver components
NVRM: have the same version.
[ 117.241243] steam[6042]: segfault at 0 ip 00000000f7c05d03 sp 00000000ffc5b558 error 4 in libc.so.6[89d03,f7b7c000+15e000] likely on CPU 0 (core 0, socket 0)
[ 117.241261] Code: c9 0f 84 fa 00 00 00 40 a8 03 74 1e 8a 08 38 ca 0f 84 16 01 00 00 84 c9 0f 84 e3 00 00 00 40 eb 09 8d b6 00 00 00 00 83 c0 10 <8b> 08 31 d1 bf ff fe fe fe 01 cf 0f 83 d3 00 00 00 31 cf 81 cf ff
[ 117.376507] evm: overlay not supporte@@bazziteazzitebazziteazzite
@bazzite:~$ nvidia-smi
Tue Aug 19 20:39:56 2025
| NVIDIA-SMI 580.76.05 Driver Version: 580.76.05 CUDA Version: 13.0 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce GTX 1660 … Off | 00000000:3C:00.0 On | N/A |
| 43% 32C P8 3W / 125W | 295MiB / 6144MiB | 5% Default |
Steam output from terminal:
[2025-08-19 20:42:40] No more messages are expected - exiting
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf603cf90
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf603b670
/var/home/Andrus/.local/share/Steam/steam.sh: line 928: 7625 Segmentation fault (core dumped) “$STEAMROOT/$STEAMEXEPATH” “$@”
Suggestions tried:
ujust update
flatpak update
reboot
– no go
suggestion to re-initlialize flatpak install -
flatpak install flathub com.valvesoftware.Steam
flatpak run com.valvesoftware.Steam
Looking for matches…
error: Nothing matches com.valvesoftware.Steam in remote flathub
error: app/com.valvesoftware.Steam/x86_64/master not installed
I don’t use bazzite, but since no one has replied:
Have you tried selecting your previous image when you boot?
(I’m assuming bazzite can do that)
@JohnAtl No i did not try it as solution, years , since i was working with Solaris, Linux has changed drastically from 1990’s.
Found its possible to make rollback thru rpm-ostree rollback - well flickering on deck screen went away, but executing steam from in terminal or taskbar pinned icon is still crashing.
EDIT:
Found reason of this whole mess - ujust update updated kernel modules to 580-76-05 , but steam is running for requesting 575-64.05 modules. bazzite’s Steam needs update to work with those libraries.
Workaround is:
install flatpak install com.valvesoftware.Steam and run in dekstop mode via command flatpak run com.valvesoftware.Steam
You need to force link (make a backup of original dir install creates in ~/.var/app/com.valvesoftware.Steam)
command: ln -s ~/.var/app/com.valvesoftware.Steam/.steam/steam ~/.local/share/Steam to get your games back without re-installing them all.
Flickering on Wayland (Game Mode) SDDM screen - no solution found to it sofar.
A attempt of doing sudo mv /usr/bin/steam /usr/bin/steam.disabled and linking shell script of flatpak run com.valvesoftware.Steam - can’t be done due read-only filesystem on /usr/bin
