This shows up as a notif when opening from keyboard shortcut or app launcher: Could not activate remote peer ‘org.kde.spectacle’: startup job failed
From terminal it says illegal instruction core dumped
renner
August 28, 2025, 1:40pm
2
Sounds similar to
opened 05:28PM - 12 Aug 25 UTC
bug
### Describe the bug
I clicked on Spectacle to take screenshots and I got this … error:
Could not activate remote peer 'org.kde.spectacle': startup job failed
Also, I want to use Discover to see apps but It doesn't open, and when I execute it from terminal I got:
Illegal instruction (core dumped)
### What did you expect to happen?
I expected both applications can open normally.
### Output of `bootc status`
```shell
● Booted image: ghcr.io/ublue-os/aurora:stable
Digest: sha256:9b01939600bb40dbf3d60c3611bf93b73114d1a68a475ec0e8cf666ea2f6a174 (amd64)
Version: 42.20250810.1 (2025-08-10T06:01:56Z)
Rollback image: ghcr.io/ublue-os/aurora:stable
### Output of `groups`
```shell
mawfy wheel plugdev
### Extra information or context
📦 OS & Version
Aurora Linux (stable) — Version: 42.20250810.1
Based on Fedora Kinoite 42
🖥 System Uptime
Running for 51 minutes
System forged (installed) on Aug 11, 2025
⚙️ Hardware
CPU: Intel Pentium G2020, 2 cores @ 2.90 GHz
GPU: NVIDIA GeForce 210 (Discrete)
Memory: 4.72 GiB used / 5.76 GiB total (~82% usage)
Storage: 16.32 GiB used / 222.57 GiB total (~7% usage), Btrfs filesystem (read-only mode)
Display: 1920×1080 @ 60 Hz on a 27" external monitor
💻 Software
KDE Plasma 6.4.4
KWin (Wayland session)
Shell: bash 5.2.37
Terminal: Ptyxis 48.5
Installed packages: 2515 rpm packages, 38 flatpaks
and maybe
opened 12:32AM - 05 Aug 25 UTC
bug
Plasma Discover Core Dump crash on Atom Z3735f (bay trail).
Issues seems to be h… ardware specific and only affects Ublue builds of Kinoite.
fedora:fedora/42/x86_64/kinoite - works fine
ghcr.io/ublue-os/kinoite-main:42 - when rebasing from fedora kinoite to ublue kinoite-main the issue appears
State: idle
Deployments:
● ostree-unverified-registry:ghcr.io/ublue-os/kinoite-main:42
Digest: sha256:ac165696a65ebed101211aa3d001bab52bfd4248fd0efbf4af292d071160e84f
Version: 42.20250804.5 (2025-08-04T21:53:17Z)
Version: 42.20250804.0 (2025-08-04T01:02:50Z)
Commit: 7861c290f13c4f001a7c42955495c9658fcd38c2b21e9708e9afa8766252d1ae
GPGSignature: Valid signature by B0F4950458F69E1150C6C5EDC8AC4916105EF944
04/08/2025 23:38 systemd-coredump Process 7972 (ddcutil) of user 0 dumped core.
Module /75/1caf2ccef045307dc3d7b251e9f96f7f99500608a81ca1cab0cd11044acfe2.file without build-id.
Module libcap.so.2 from rpm libcap-2.73-2.fc42.x86_64
Module libpcre2-8.so.0 from rpm pcre2-10.45-1.fc42.x86_64
Module libdrm.so.2 from rpm libdrm-2.4.125-1.fc42.x86_64
Module libudev.so.1 from rpm systemd-257.7-1.fc42.x86_64
Module libglib-2.0.so.0 from rpm glib2-2.84.3-1.fc42.x86_64
Module libjansson.so.4 from rpm jansson-2.14-2.fc42.x86_64
Stack trace of thread 7972:
#0 0x00007ff46eb8d67a __strlen_sse2 (libc.so.6 + 0x9467a)
#1 0x0000558321c9d2ed n/a (/75/1caf2ccef045307dc3d7b251e9f96f7f99500608a81ca1cab0cd11044acfe2.file + 0x782ed)
#2 0x0000558321cadffc n/a (/75/1caf2ccef045307dc3d7b251e9f96f7f99500608a81ca1cab0cd11044acfe2.file + 0x88ffc)
#3 0x0000558321cae855 n/a (/75/1caf2ccef045307dc3d7b251e9f96f7f99500608a81ca1cab0cd11044acfe2.file + 0x89855)
#4 0x0000558321cae98c n/a (/75/1caf2ccef045307dc3d7b251e9f96f7f99500608a81ca1cab0cd11044acfe2.file + 0x8998c)
#5 0x0000558321c2e486 n/a (/75/1caf2ccef045307dc3d7b251e9f96f7f99500608a81ca1cab0cd11044acfe2.file + 0x9486)
#6 0x00007ff46eafc5f5 __libc_start_call_main (libc.so.6 + 0x35f5)
#7 0x00007ff46eafc6a8 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x36a8)
#8 0x0000558321c2e5d5 n/a (/75/1caf2ccef045307dc3d7b251e9f96f7f99500608a81ca1cab0cd11044acfe2.file + 0x95d5)
ELF object binary architecture: AMD x86-64
Difference between fedora:fedora/42/x86_64/kinoite and ghcr.io/ublue-os/kinoite-main:42
ostree diff commit from: rollback deployment (7861c290f13c4f001a7c42955495c9658fcd38c2b21e9708e9afa8766252d1ae)
ostree diff commit to: booted deployment (8fff9f249f54724ff5f10a0ca815644d081e29405b95078fd8078b40d5dcd796)
Upgraded:
intel-gmmlib 22.7.2-1.fc42 -> 1:22.7.2-1.fc42
intel-mediasdk 23.2.2-7.fc42 -> 1:23.2.2-1.fc42
libva 2.22.0-4.fc42 -> 1:2.22.0-1.fc42
libva-intel-media-driver 25.2.6-1.fc42 -> 1:25.2.5-1.fc42
mesa-dri-drivers 25.1.4-2.fc42 -> 1:25.1.4-1.fc42
mesa-filesystem 25.1.4-2.fc42 -> 1:25.1.4-1.fc42
mesa-libEGL 25.1.4-2.fc42 -> 1:25.1.4-1.fc42
mesa-libGL 25.1.4-2.fc42 -> 1:25.1.4-1.fc42
mesa-libgbm 25.1.4-2.fc42 -> 1:25.1.4-1.fc42
mesa-va-drivers 25.1.4-2.fc42 -> 1:25.1.4-1.fc42
mesa-vulkan-drivers 25.1.4-2.fc42 -> 1:25.1.4-1.fc42
Downgraded:
glibc 2.41-10.fc42 -> 2.41-9.fc42
glibc-all-langpacks 2.41-10.fc42 -> 2.41-9.fc42
glibc-common 2.41-10.fc42 -> 2.41-9.fc42
glibc-gconv-extra 2.41-10.fc42 -> 2.41-9.fc42
libinput 1.29.0-1.fc42 -> 1.28.903-1.fc42
libsss_certmap 2.11.1-1.fc42 -> 2.11.0-1.fc42
libsss_idmap 2.11.1-1.fc42 -> 2.11.0-1.fc42
libsss_nss_idmap 2.11.1-1.fc42 -> 2.11.0-1.fc42
libsss_sudo 2.11.1-1.fc42 -> 2.11.0-1.fc42
sssd-client 2.11.1-1.fc42 -> 2.11.0-1.fc42
sssd-common 2.11.1-1.fc42 -> 2.11.0-1.fc42
sssd-kcm 2.11.1-1.fc42 -> 2.11.0-1.fc42
sssd-krb5-common 2.11.1-1.fc42 -> 2.11.0-1.fc42
sssd-nfs-idmap 2.11.1-1.fc42 -> 2.11.0-1.fc42
Removed:
OpenCL-ICD-Loader-3.0.6-2.20241023git5907ac1.fc42.x86_64
default-fonts-cjk-sans-4.2-4.fc42.noarch
fdk-aac-free-2.0.0-15.fc42.x86_64
ffmpeg-free-7.1.1-4.fc42.x86_64
google-noto-sans-cjk-vf-fonts-1:2.004-9.fc42.noarch
libavcodec-free-7.1.1-4.fc42.x86_64
libavdevice-free-7.1.1-4.fc42.x86_64
libavfilter-free-7.1.1-4.fc42.x86_64
libavformat-free-7.1.1-4.fc42.x86_64
libavutil-free-7.1.1-4.fc42.x86_64
libpostproc-free-7.1.1-4.fc42.x86_64
libswresample-free-7.1.1-4.fc42.x86_64
libswscale-free-7.1.1-4.fc42.x86_64
plasma-discover-rpm-ostree-6.4.3-1.fc42.x86_64
Added:
LCEVCdec-3.3.8-2.fc42.x86_64
alsa-firmware-1.2.4-14.fc42.noarch
alsa-tools-firmware-1.2.14-1.fc42.x86_64
android-udev-rules-20241019-1.fc42.noarch
apr-1.7.5-2.fc42.x86_64
apr-util-1.6.3-22.fc42.x86_64
apr-util-lmdb-1.6.3-22.fc42.x86_64
apr-util-openssl-1.6.3-22.fc42.x86_64
cosign-2.5.3-1.x86_64
davs2-libs-1.7^20220903gitb41cf11-6.fc42.x86_64
distrobox-1.8.1.2-1.fc42.noarch
dnf5-5.2.15.0-2.fc42.x86_64
dnf5-plugins-5.2.15.0-2.fc42.x86_64
fcitx5-5.1.13-1.fc42.x86_64
fcitx5-chinese-addons-5.1.9-2.fc42.x86_64
fcitx5-chinese-addons-data-5.1.9-2.fc42.noarch
fcitx5-configtool-5.1.10-2.fc42.x86_64
fcitx5-data-5.1.13-1.fc42.noarch
fcitx5-gtk-5.1.4-1.fc42.x86_64
fcitx5-gtk2-5.1.4-1.fc42.x86_64
fcitx5-gtk3-5.1.4-1.fc42.x86_64
fcitx5-gtk4-5.1.4-1.fc42.x86_64
fcitx5-hangul-5.1.7-1.fc42.x86_64
fcitx5-libs-5.1.13-1.fc42.x86_64
fcitx5-libthai-5.1.6-1.fc42.x86_64
fcitx5-lua-5.0.15-1.fc42.x86_64
fcitx5-mozc-2.30.5618.102-3.20250124gitc0ed34e.s20250101gite5b3425.s20250101gitv3.29.1.fc42.x86_64
fcitx5-qt-5.1.10-3.fc42.x86_64
fcitx5-qt-libfcitx5qt6widgets-5.1.10-3.fc42.x86_64
fcitx5-qt-libfcitx5qtdbus-5.1.10-3.fc42.x86_64
fcitx5-qt-qt6gui-5.1.10-3.fc42.x86_64
fcitx5-qt5-5.1.10-3.fc42.x86_64
fcitx5-qt6-5.1.10-3.fc42.x86_64
fcitx5-sayura-5.1.4-1.fc42.x86_64
fcitx5-unikey-5.1.7-1.fc42.x86_64
ffmpeg-1:7.1.1-3.fc42.x86_64
ffmpeg-libs-1:7.1.1-3.fc42.x86_64
flatpak-spawn-1.0.6-2.fc42.x86_64
fxload-2008_10_13-30.fc42.x86_64
fzf-0.62.0-1.fc42.x86_64
google-noto-sans-balinese-fonts-20250301-1.fc42.noarch
google-noto-sans-cjk-fonts-1:2.004-9.fc42.noarch
google-noto-sans-javanese-fonts-20250301-1.fc42.noarch
google-noto-sans-sundanese-fonts-20250301-1.fc42.noarch
gpm-libs-1.20.7-51.fc42.x86_64
grub2-tools-extra-1:2.12-32.fc42.x86_64
gtest-1.15.2-3.fc42.x86_64
heif-pixbuf-loader-1:1.19.8-1.fc42.x86_64
htop-3.4.1-1.fc42.x86_64
hwloc-libs-2.12.0-1.fc42.x86_64
icoutils-0.32.3-17.fc41.x86_64
intel-vaapi-driver-1:2.4.1-8.fc42.x86_64
just-1.42.3-1.fc42.x86_64
kate-25.04.3-1.fc42.x86_64
kate-krunner-plugin-6.4.3-1.fc42.x86_64
kate-plugins-25.04.3-1.fc42.x86_64
kcm-fcitx5-5.1.10-2.fc42.x86_64
ksshaskpass-6.4.3-1.fc42.x86_64
kvazaar-libs-2.3.1-2.fc42.x86_64
libavcodec-1:7.1.1-3.fc42.x86_64
libavdevice-1:7.1.1-3.fc42.x86_64
libavfilter-1:7.1.1-3.fc42.x86_64
libavformat-1:7.1.1-3.fc42.x86_64
libavutil-1:7.1.1-3.fc42.x86_64
libcamera-gstreamer-0.4.0-4.fc42.x86_64
libcamera-tools-0.4.0-4.fc42.x86_64
libdnf5-5.2.15.0-2.fc42.x86_64
libdnf5-cli-5.2.15.0-2.fc42.x86_64
libdnf5-plugin-expired-pgp-keys-5.2.15.0-2.fc42.x86_64
libfdk-aac-1:2.0.3-2.fc42.x86_64
libfreeaptx-0.2.2-1.fc42.x86_64
libime-1.1.11-1.fc42.x86_64
libime-data-1.1.11-1.fc42.noarch
libimobiledevice-utils-1.3.0^20240916gited9703d-5.fc42.x86_64
libnpp-1:12.3.3.65-1.fc42.x86_64
libpostproc-1:7.1.1-3.fc42.x86_64
libratbag-ratbagd-0.18-3.fc42.x86_64
librtmp-1:2.6^20240301git6f6bb13-2.fc42.x86_64
libswresample-1:7.1.1-3.fc42.x86_64
libswscale-1:7.1.1-3.fc42.x86_64
libtatsu-1.0.3-2.fc42.x86_64
libva-utils-1:2.22.0-1.fc42.x86_64
libxavs-0.1.55~20110821svnr55-2.fc42.x86_64
libyubikey-1.13-25.fc42.x86_64
lshw-B.02.20-6.fc42.x86_64
mailcap-2.1.54-8.fc42.noarch
marisa-0.2.6-13.fc42.x86_64
mesa-libxatracker-1:25.1.4-1.fc42.x86_64
mtools-4.0.49-1.fc42.x86_64
nvtop-3.2.0-3.fc42.x86_64
ocl-icd-2.3.2-8.fc42.x86_64
opencc-1.1.9-1.fc42.x86_64
openrgb-udev-rules-0.9-17.20250311git28e97cf.fc42.noarch
oversteer-udev-0.0.git.362.0561f316-1.fc41.noarch
pam-u2f-1.3.2-1.fc42.x86_64
pam_yubico-2.27-8.fc42.x86_64
pamu2fcfg-1.3.2-1.fc42.x86_64
perl-AutoLoader-5.74-518.fc42.noarch
perl-B-1.89-518.fc42.x86_64
perl-Carp-1.54-512.fc42.noarch
perl-Class-Struct-0.68-518.fc42.noarch
perl-Clone-0.47-2.fc42.x86_64
perl-Compress-Raw-Bzip2-2.213-2.fc42.x86_64
perl-Compress-Raw-Zlib-2.213-2.fc42.x86_64
perl-Data-Dump-1.25-12.fc42.noarch
perl-Data-Dumper-2.189-513.fc42.x86_64
perl-Digest-1.20-512.fc42.noarch
perl-Digest-HMAC-1.05-2.fc42.noarch
perl-Digest-MD5-2.59-6.fc42.x86_64
perl-Digest-SHA-1:6.04-513.fc42.x86_64
perl-DynaLoader-1.56-518.fc42.x86_64
perl-Encode-4:3.21-512.fc42.x86_64
perl-Encode-Locale-1.05-31.fc42.noarch
perl-Errno-1.38-518.fc42.x86_64
perl-Exporter-5.78-512.fc42.noarch
perl-Fcntl-1.18-518.fc42.x86_64
perl-File-Basename-2.86-518.fc42.noarch
perl-File-Copy-2.41-518.fc42.noarch
perl-File-Listing-6.16-5.fc42.noarch
perl-File-Path-2.18-512.fc42.noarch
perl-File-Slurper-0.014-7.fc42.noarch
perl-File-Temp-1:0.231.100-512.fc42.noarch
perl-File-stat-1.14-518.fc42.noarch
perl-FileHandle-2.05-518.fc42.noarch
perl-Getopt-Long-1:2.58-3.fc42.noarch
perl-Getopt-Std-1.14-518.fc42.noarch
perl-HTML-Parser-3.83-2.fc42.x86_64
perl-HTML-Tagset-3.24-3.fc42.noarch
perl-HTTP-Cookies-6.11-5.fc42.noarch
perl-HTTP-Date-6.06-6.fc42.noarch
perl-HTTP-Message-7.00-2.fc42.noarch
perl-HTTP-Negotiate-6.01-40.fc42.noarch
perl-HTTP-Tiny-0.090-2.fc42.noarch
perl-I18N-Langinfo-0.24-518.fc42.x86_64
perl-IO-1.55-518.fc42.x86_64
perl-IO-Compress-2.213-3.fc42.noarch
perl-IO-Compress-Brotli-0.004001-15.fc42.x86_64
perl-IO-HTML-1.004-14.fc42.noarch
perl-IO-Socket-IP-0.43-2.fc42.noarch
perl-IO-Socket-SSL-2.089-2.fc42.noarch
perl-IPC-Open3-1.22-518.fc42.noarch
perl-LWP-MediaTypes-6.04-20.fc42.noarch
perl-MIME-Base32-1.303-23.fc42.noarch
perl-MIME-Base64-3.16-512.fc42.x86_64
perl-Module-Load-1:0.36-512.fc42.noarch
perl-NDBM_File-1.17-518.fc42.x86_64
perl-NTLM-1.09-40.fc42.noarch
perl-Net-HTTP-6.23-6.fc42.noarch
perl-Net-SSLeay-1.94-8.fc42.x86_64
perl-POSIX-2.20-518.fc42.x86_64
perl-PathTools-3.91-513.fc42.x86_64
perl-PerlIO-utf8_strict-0.010-9.fc42.x86_64
perl-Pod-Escapes-1:1.07-512.fc42.noarch
perl-Pod-Perldoc-3.28.01-513.fc42.noarch
perl-Pod-Simple-1:3.45-512.fc42.noarch
perl-Pod-Usage-4:2.05-1.fc42.noarch
perl-Scalar-List-Utils-5:1.70-1.fc42.x86_64
perl-SelectSaver-1.02-518.fc42.noarch
perl-Socket-4:2.038-512.fc42.x86_64
perl-Storable-1:3.32-512.fc42.x86_64
perl-Symbol-1.09-518.fc42.noarch
perl-Term-ANSIColor-5.01-513.fc42.noarch
perl-Term-Cap-1.18-512.fc42.noarch
perl-Term-ReadLine-1.17-518.fc42.noarch
perl-Text-ParseWords-3.31-512.fc42.noarch
perl-Text-Tabs+Wrap-2024.001-512.fc42.noarch
perl-Time-HiRes-4:1.9777-512.fc42.x86_64
perl-Time-Local-2:1.350-512.fc42.noarch
perl-TimeDate-1:2.33-16.fc42.noarch
perl-Try-Tiny-0.32-2.fc42.noarch
perl-URI-5.31-2.fc42.noarch
perl-WWW-RobotRules-6.02-41.fc42.noarch
perl-base-2.27-518.fc42.noarch
perl-constant-1.33-513.fc42.noarch
perl-if-0.61.000-518.fc42.noarch
perl-interpreter-4:5.40.2-518.fc42.x86_64
perl-libnet-3.15-513.fc42.noarch
perl-libs-4:5.40.2-518.fc42.x86_64
perl-libwww-perl-6.77-3.fc42.noarch
perl-locale-1.12-518.fc42.noarch
perl-mro-1.29-518.fc42.x86_64
perl-overload-1.37-518.fc42.noarch
perl-overloading-0.02-518.fc42.noarch
perl-parent-1:0.244-2.fc42.noarch
perl-podlators-1:6.0.2-3.fc42.noarch
perl-subs-1.04-518.fc42.noarch
perl-vars-1.05-518.fc42.noarch
pipewire-libs-extra-1.4.7-1.fc42.x86_64
powerstat-0.04.03-2.fc42.x86_64
python3-cffi-1.17.1-2.fc42.x86_64
python3-cryptography-44.0.0-3.fc42.x86_64
python3-evdev-1.9.1-1.fc42.x86_64
python3-fido2-1.2.0-2.fc42.noarch
python3-jaraco-classes-3.4.0-6.fc42.noarch
python3-jaraco-context-6.0.1-5.fc42.noarch
python3-jaraco-functools-4.1.0-2.fc42.noarch
python3-jeepney-0.8.0-11.fc42.noarch
python3-keyring-25.6.0-2.fc42.noarch
python3-keyring+completion-25.6.0-2.fc42.noarch
python3-more-itertools-10.5.0-2.fc42.noarch
python3-ply-3.11-26.fc42.noarch
python3-pycparser-2.20-19.fc42.noarch
python3-pyscard-2.0.5-10.fc42.x86_64
python3-secretstorage-3.3.3^20240314git3e5097c-10.fc42.noarch
python3-shtab-1.7.1-4.fc42.noarch
python3-yubikey-manager-5.7.1-3.20250726git6641bf0.fc42.noarch
sdbus-cpp-1.5.0-4.fc42.x86_64
solaar-udev-1.1.14-8.fc42.noarch
squashfs-tools-4.6.1-6.fc42.x86_64
svt-vp9-libs-0.3.0-15.fc42.x86_64
symlinks-1.7-12.fc42.x86_64
tcpdump-14:4.99.5-4.fc42.x86_64
tmux-3.5a-4.fc42.x86_64
traceroute-3:2.1.6-2.fc42.x86_64
uavs3d-libs-1.2.0~20230223git1fd0491-5.fc42.x86_64
ublue-os-akmods-addons-0.6-1.fc42.noarch
ublue-os-just-0.48-1.fc42.noarch
ublue-os-luks-0.3-1.fc42.noarch
ublue-os-signing-0.5-1.fc42.noarch
ublue-os-udev-rules-0.11-1.fc42.noarch
ublue-os-update-services-0.91-1.fc42.noarch
vim-common-2:9.1.1591-1.fc42.x86_64
vim-enhanced-2:9.1.1591-1.fc42.x86_64
vim-filesystem-2:9.1.1591-1.fc42.noarch
vvenc-libs-1.13.1-1.fc42.x86_64
wireguard-tools-1.0.20210914-9.fc42.x86_64
wl-clipboard-2.2.1-4.fc42.x86_64
x264-libs-1:0.164-37.20250311git27d8370.fc42.x86_64
x265-libs-1:4.1-3.fc42.x86_64
xavs2-libs-1.4-1.fc42.x86_64
xcb-imdkit-1.0.9-4.fc42.x86_64
xxd-2:9.1.1591-1.fc42.x86_64
ykclient-2.15-21.fc42.x86_64
ykpers-1.20.0-16.fc42.x86_64
zstd-1.5.7-1.fc42.x86_64
no one (with the hardware) has investigated this issue so far, it’s likely hardware related.
Both of them have older intel CPUs.
It also affected me I have an Intel Pentium N6000 I’m trying the fix you suggested in Discover and Spectacle don't open · Issue #828 · ublue-os/aurora · GitHub if it works I’ll get back to you
I tried the first bootc and it didn’t work now I’m going to try the second one
@renner info symbol $rip _sub_I_65535_0.0 + 1382 in section .text of /lib64/liblcevc_dec_api.so.4 it seems that a library is using avx instructions when cpus that are like mine or older don’t have it so it crashes when it gets to the library
renner
September 7, 2025, 5:33pm
6
Thank you.
I added some things you could try to perhaps narrow it down further. Likely an upstream bug.
bug
```shell
```shell
mawfy wheel plugdev
📦 OS & Version
🖥 System Uptime
⚙️ Hardware
💻 Software
KDE Plasma 6.4.4
Shell: bash 5.2.37
@renner I tried it for Bazzite and the 0620 version does not have it now Spectacle works
