[Solved] Bazzite won't update
Hi all,
I have a warning that my system doesn’t update for a month and i can update it manually.
When i run a manual update i have this error :
➜ sudo rpm-ostree upgrade
[sudo] Mot de passe de olivier :
Pulling manifest: ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-gnome-nvidia-open:stable
Checking out tree a1a09ef... done
Enabled rpm-md repositories: updates fedora terra-mesa updates-archive
Importing rpm-md... done
rpm-md repo 'updates' (cached); generated: 2026-01-13T00:44:49Z solvables: 19467
rpm-md repo 'fedora' (cached); generated: 2025-10-23T03:37:20Z solvables: 77664
rpm-md repo 'terra-mesa' (cached); generated: 2025-12-29T14:51:50Z solvables: 105
rpm-md repo 'updates-archive' (cached); generated: 2026-01-13T01:03:49Z solvables: 23796
Will download: 5 packages (2,2 Mo)
Downloading from 'updates'... done
Importing packages... done
Relabeling... done
Checking out packages... done
error: Checkout gnome-shell-extension-appindicator-61-1.fc43.noarch: Hardlinking ba/ac27d4293524fc1128aa2839a5fdaf0b1ddf0bf27dc0992f9c0749aeabe069.file to metadata.json: Le fichier existe
I try to reinstall gnome-shell-extension-appindicator-61-1.fc43.noarch, “override reset -a”, “rpm-ostree reset” but that are not effect.
Any ideas to resolv it ?
Here my rpm-ostree status :
State: idle
Deployments:
● ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-gnome-nvidia-open:stable
                   Digest: sha256:1447f5d2c75e0db844a65b80db15273beb5950847dcc02f13d9215e315b5a97e
                  Version: 43.20251029 (2025-10-29T18:45:35Z)
          LayeredPackages: gdk-pixbuf2-modules-extra glib2-devel gnome-tweak-tool nc rhythmbox
                           solaar zpaq zsh
      RemovedBasePackages: gnome-shell-extension-appindicator 61-1.fc43
                           solaar zpaq zsh
You need to remove layered packages. Layering packages can prevent updates. Not all layered packages causes this issue, but you have several of them and I’m almost sure is the root cause of the problem.
Thanks a lot. I understand my error and i can solve it.
