For the information, I use aurora-dx-nvidia-open:latest.
I tried playing videos on Haruna, it used software decoding (CPU).
I tried checking codec on Firefox about:support, it also showed no hardware decoding.
Meanwhile when I tried to record using OBS, I could encode on it no problem.
When I plugged my RTX 2000 Ada Generation (RTX 40 Series/Ada Lovelace equivalent), it worked properly.
If I boot to Windows, everything on the 5070 Ti (encoder/decoder) works properly.
I already updated flatpak to get the latest org.freedesktop.Platform.GL.nvidia and org.freedesktop.Platform.GL32.nvidia (570.133.07). Is there anything I can do? Or even get the log about the problem?
