I unsuccessfully tried to layer install the F5 BIGIP VPN client with the following output. I assume this is likely going to be a no-go? Suggestions welcome. Installed Bazzite Gnome Asus over weekend on my laptop and very impressed. Everything “just works”. Well, except for this and the ability to do my job.
Although this isn’t my work laptop I still need the ability to respond to emergencies when I only take my personal laptop on pleasure trips.
Fantastic work and very exciting future. Thank you all for your hard work, vision, and determination toward the future.
Oh yeah, the issue:
Relabeling... done
Checking out packages... done
Running pre scripts... done
Running post scripts... done
error: Running %post for f5vpn: bwrap(/bin/sh): Child process killed by signal 1; run `journalctl -t 'rpm-ostree(f5vpn.post)'` for more information
michael@popstop:~/Downloads$ journalctl -t 'rpm-ostree(f5vpn.post)'
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13861]: /proc/self/fd/5: line 2: cd: /opt/f5/vpn: No such file or directory
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13868]: chown: cannot access '/opt/f5/vpn/svpn': No such file or directory
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13869]: chmod: cannot access '/opt/f5/vpn/svpn': No such file or directory
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13870]: mkdir: cannot create directory ‘/usr/local’: File exists
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13872]: xdg-desktop-menu: file 'com.f5.f5vpn.desktop' does not exist
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13874]: xdg-icon-resource: file '/opt/f5/vpn/logos/1024x1024.png' does not exist
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13877]: xdg-icon-resource: file '/opt/f5/vpn/logos/512x512.png' does not exist
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13880]: xdg-icon-resource: file '/opt/f5/vpn/logos/256x256.png' does not exist
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13883]: xdg-icon-resource: file '/opt/f5/vpn/logos/128x128.png' does not exist
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13886]: xdg-icon-resource: file '/opt/f5/vpn/logos/96x96.png' does not exist
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13889]: xdg-icon-resource: file '/opt/f5/vpn/logos/64x64.png' does not exist
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13892]: xdg-icon-resource: file '/opt/f5/vpn/logos/48x48.png' does not exist
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13895]: xdg-icon-resource: file '/opt/f5/vpn/logos/32x32.png' does not exist
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13898]: xdg-icon-resource: file '/opt/f5/vpn/logos/24x24.png' does not exist
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13901]: xdg-icon-resource: file '/opt/f5/vpn/logos/16x16.png' does not exist
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13904]: cp: cannot stat 'com.f5.f5vpn.service': No such file or directory
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13905]: Failed to set capabilities on file `/opt/f5/vpn/f5vpn' (No such file or directory)
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13905]: usage: setcap [-h] [-q] [-v] [-n <rootid>] (-r|-|<caps>) <filename> [ ... (-r|-|<capsN>) <>
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13905]: Note <filename> must be a regular (non-symlink) file.
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13905]: -r remove capability from file
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13905]: - read capability text from stdin
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13905]: <capsN> cap_from_text(3) formatted file capability
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13905]: -h this message and exit status 0
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13905]: -q quietly
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13905]: -v validate supplied capability matches file
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13905]: -n <rootid> write a user namespace limited capability
Apr 22 17:55:41 popstop.lan rpm-ostree(f5vpn.post)[13905]: --license display the license info
Apr 22 18:19:58 popstop.lan rpm-ostree(f5vpn.post)[19521]: /proc/self/fd/5: line 2: cd: /opt/f5/vpn: No such file or directory
Apr 22 18:19:58 popstop.lan rpm-ostree(f5vpn.post)[19526]: chown: cannot access '/opt/f5/vpn/svpn': No such file or directory
Apr 22 18:19:58 popstop.lan rpm-ostree(f5vpn.post)[19527]: chmod: cannot access '/opt/f5/vpn/svpn': No such file or directory
Apr 22 18:19:58 popstop.lan rpm-ostree(f5vpn.post)[19528]: mkdir: cannot create directory ‘/usr/local’: File exists
Apr 22 18:19:58 popstop.lan rpm-ostree(f5vpn.post)[19529]: xdg-desktop-menu: file 'com.f5.f5vpn.desktop' does not exist
Apr 22 18:19:58 popstop.lan rpm-ostree(f5vpn.post)[19531]: xdg-icon-resource: file '/opt/f5/vpn/logos/1024x1024.png' does not exist
Apr 22 18:19:58 popstop.lan rpm-ostree(f5vpn.post)[19535]: xdg-icon-resource: file '/opt/f5/vpn/logos/512x512.png' does not exist
Apr 22 18:19:58 popstop.lan rpm-ostree(f5vpn.post)[19538]: xdg-icon-resource: file '/opt/f5/vpn/logos/256x256.png' does not exist
Apr 22 18:19:58 popstop.lan rpm-ostree(f5vpn.post)[19542]: xdg-icon-resource: file '/opt/f5/vpn/logos/128x128.png' does not exist
Apr 22 18:19:59 popstop.lan rpm-ostree(f5vpn.post)[19545]: xdg-icon-resource: file '/opt/f5/vpn/logos/96x96.png' does not exist
Apr 22 18:19:59 popstop.lan rpm-ostree(f5vpn.post)[19548]: xdg-icon-resource: file '/opt/f5/vpn/logos/64x64.png' does not exist
Apr 22 18:19:59 popstop.lan rpm-ostree(f5vpn.post)[19551]: xdg-icon-resource: file '/opt/f5/vpn/logos/48x48.png' does not exist
Apr 22 18:19:59 popstop.lan rpm-ostree(f5vpn.post)[19554]: xdg-icon-resource: file '/opt/f5/vpn/logos/32x32.png' does not exist
Apr 22 18:19:59 popstop.lan rpm-ostree(f5vpn.post)[19557]: xdg-icon-resource: file '/opt/f5/vpn/logos/24x24.png' does not exist
Apr 22 18:19:59 popstop.lan rpm-ostree(f5vpn.post)[19560]: xdg-icon-resource: file '/opt/f5/vpn/logos/16x16.png' does not exist
Apr 22 18:19:59 popstop.lan rpm-ostree(f5vpn.post)[19563]: cp: cannot stat 'com.f5.f5vpn.service': No such file or directory
