Remote share mounting
i have an unraid server and i want to give bazzite a solid go for getting away from microslop so i have a question on the mounting
on windows, i usually point my pictures, videos, documents, etc folders to folders on my NAS. on windows its just go into properties and set the location to a mounted share, like Z:unraid share/pictures. now i found a site with info on mounting shares under bazzite and i’m curious if i can do this as well
the site mentions making a mount unit with
# The network share (SMB/CIFS) that will be mounted.
What=//<yourRemoteServerIP>/<yourRemoteFolder>
# Replace with actual IP and share name, e.g., //192.168.1.100/retrodeck.
# Local mount point where the share will be attached.
Where=/var/home/<username>/retrodeck
# Replace <username> and <retrodeck> with actual values. Make sure that it matches with the folder you create as mount folder.
if i make the network point my smb: servername/username/foldername
and the local mount point my home/user/pictures folder
is that it? or do i need to mount the entire smb drives somehow too, like in windows where you have a Z:/server folder then i mount the local folders to the drive afterwards.
thank you in advance!
