Rebasing from encrypted Fedora IoT?
Hello,
I am trying to convert from Fedora IoT to ucore-minimal. I used the manual rebase instructions from the github repo, but I am stuck unable to boot into ucore.
I get past decrypting the LUKS volume, then the system times out waiting for the logical volumes by UUID. Then I don’t see any of the logical volumes in the emergency console once the boot fails. I can still boot into the old IoT if I select that instead.
Is there a way I can adjust things to get ucore to discover the logical volumes?
Thank you
