Plasmashell segfaults on login
I am running aurora-dx-nvidia:latest (41.20250316.2) on a Thinkpad P52 .
After upgrading to latest-41.20250318.2 , SDDM starts normally and at login, plasmashell immediately segfaults. I was able to get the crash info for possible reporting to KDE bugzilla. I tried it 3 times same result then booted back into 41.20250316.2 .
Just thought I would check if this is a one off problem or more wide scale. It did give me the opportunity to practice pinning a deployment.
Solved
Cleared ~/.cache , that fixed plasmashell from crashing, but still had problems with various plasma components, systemsettings being the most affected. Since I was short on time, I choose the heavy handed approach, I restored ~/.local from a backup of a known working date. Not a very elegant solution but it worked.
