I’m trying to get Ollama working with Bazzite (to make use of my AMD iGPU when not gaming) but am not sure where to start. H…hh…hallppp ![]()
You can follow the explanation on hub.docker.com
https://hub.docker.com/r/ollama/ollama
Instead of docker use podman
I do it with brew install ollama - even simpler than running a docker image. Then just follow the prompts to get it to auto start, etc
That is… I used to. Until I found this which can download and run it for you in a chat UI, as well as other LLMs (sidestepping the terminal):
Both are strongly recommended - have fun! ![]()
That’s also a possibility. It depends on how you want to use it. ![]()
