Has ujust ollama-web been removed?
❯ ujust ollama-web
error: Justfile does not contain recipe `ollama-web`.
I then tried
❯ ujust ollama install-open-webui
open-webui container already exists, skipping...
Ollama Web UI container started. You can access it at http://localhost:8080
But neither Ollama or Open WebUI are actually running. If I run ollama serve and then ollama list I can see that my models exist, but no open-webui.
This thread still mentions ujust ollama-web
Hello,
I posted that comment you quote. That had nothing to do with ollama, I was just trying to get pytorch to run on my AMD GPU with acceleration (which worked).
I was not aware of ujust ollama but I tried it just now with the same results you posted. There seems to be no web interface running, just regular ollama which I interact with from the terminal window with ollama run <model>
It’s just ujust ollama now:
❯ ujust ollama
Usage: ujust ollama <option>
  <option>: Specify the quick option to skip the prompt
  Use 'install' to Install ollama container
  Use 'install-open-webui' to Install open-webui container
  Use 'remove' to remove the ollama container
  Use 'remove-open-webui' to remove the open-webui container and persistent volume
That page is old so I’ve hidden it. AI and Machine Learning is the docs page.
I read the ujust recipe and it seems to install a user systemd service. Check:
> ls ~/.config/containers/systemd/
ollama.container  ollama.network  ollama-web.container
> systemctl status --user ollama-web.service
○ ollama-web.service - An Ollama WebUI container
     Loaded: loaded (/var/home/myuser/.config/containers/systemd/ollama-web.container; generated)
    Drop-In: /usr/lib/systemd/user/service.d
             └─10-timeout-abort.conf
     Active: inactive (dead)
I tried start but it timed out and failed:
> systemctl start --user ollama-web.service
Reading the logs, it seems you need to stop the daemon. It may have worked for you but if not, try:
> brew services
Name   Status  User            File
ollama started myuser         ~/.config/systemd/user/homebrew.ollama.service
If the service is running, stop it:
> brew services stop ollama
Stopping `ollama`... (might take a while)
# should work now!
systemctl start --user ollama-web.service worked for me.
I did uninstall / reinstall though so that might have set some things right. My models still exist, as does my open-webui login+cookies, but the chat history is gone (fine in my case)
ujust ollama remove
ujust ollama remove-open-webui
Previously ujust ollama-web would also start the service. But it looks like that’s a separate step?
So personally I had configured the brew service to start automatically, which is why it was already running in my case. Stopping it fixed things for me as well, which seems to indicate that it still tries to start the service (which was failing for me due to it already running?).
I can’t reboot right now but I suspect that if you restart, it should start everything automatically.
I just tested reboot and it doesn’t start automatically (It’s not enabled for me).
I don’t need it running all the time.
I’ve put that in a script for now
 echo "systemctl start --user ollama-web.service" > start-ollama-web.sh
Might be handy to have a ujust ollama start-open-webui.
I suspect ollama uses a bit of RAM so it’s not set to autostart.
I was going to suggest the standard way of enabling systemd services, but got:
> systemctl --user enable ollama-web.service
Failed to enable unit: Unit /run/user/1400601103/systemd/generator/ollama-web.service is transient or generated.
Not sure what that is about (never seen this before), but generally systemd would auto-start services on login if you enabled it this way. Perhaps this will work for you though?
If not, another idea is to create a desktop file for running your script in folder ~/.config/autostart.
Or perhaps someone more knowledgable can suggest something better…
That’s some high quality documentation! If I could edit the page, I’d probably change the bit about checking Pytorch to read python -c "import torch; print(torch.cuda.is_available())", though I suppose most people running the NGC are going to recognize that they were supposed to start a Python interpreter to execute the commands.
Just a heads up that we’re removing the service units and justfiles from new installs. (Too many support footguns)
If you’ve installed it already then it’ll still be there. Going forward we’re just going to recommend that users install Alpaca.
Damn any time I look at these docs, things have gotten even simpler and even better. Straight ollama works great, but now there’s even just a simple flatpak app! Thank you for all the hard work, everyone!
So I updated and the ollama stuff is removed from ujust.
But now I’ve tried to delete ollama from brew and no matter what if I try to delete the container from podman it just respawns.
How do I get rid of this thing now?
Is the service active? Make sure you stop it and remove the config.
systemctl --user stop ollama
mkdir ~/backup
mv ~/.config/containers/systemd/ollama* ~/backup/
systemctl --user daemon-reload
This has cleared this up for me and I am using Alpaca. Hope it helps…
EDIT: Forgot to mention that models are downloaded to ~/.ollama so you may want to clean that up to save space…
Yep that did it. Thanks!
I don’t see ujust ollama in Aurora. Is it there somewhere? Aurora
Removed a while back.
Ok. Should I just install using the traditional script? Will that work?
I would do brew install ollama. EDIT: the installation script from the ollama website works, but I had to mess around with path and stuff to get it working. I’d recommend brew.
Maybe we should add this to the docs. It only recommends alpaca for the visual UI, which I use, but sometimes you need straight Ollama server too. EDIT: Update ai to include mention of straight ollama and not just alpaca by nikodunk · Pull Request #77 · ublue-os/bluefin-docs · GitHub
But if I simply install Alpaca and download LLMs through its GUI (which is great, because it doesn’t involve the terminal and automatically recognizes and uses my GPU), will I be able to use those models (aka the “underlying” ollama instance) from other programs as well?
For example, Jetbrains IDEs can now be connected to a local ollama instance by specifying IP address and port, but I’ve noticed that the classic localhost:11434 doesn’t work if ollama is installed just inside Alpaca.
Is it just that it uses a different port? Or it simply can’t work outside of the Alpaca app?
