i’ve downloaded genshin impact to play on linux and although the launcher works, when i attempt to launch the game it crashes. this was included in the log file for the game: WARNING: [Loader Message] Code 0 : terminator_CreateInstance: Received return code -9 from call to vkCreateInstance in ICD /usr/lib64/libvulkan_dzn.so. Skipping this driver. WARNING: [Loader Message] Code 0 : ICD for selected physical device does not export vkGetPhysicalDeviceDisplayPlanePropertiesKHR! WARNING: [Loader Message] Code 0 : ICD for selected physical device does not export vkGetPhysicalDeviceDisplayPropertiesKHR! ========== VULKANINFO ========== Vulkan Instance Version: 1.4.341 Instance Extensions: count = 27 =============================== VK_EXT_acquire_drm_display : extension revision 1
Easiest way is to try twintail launcher from flathub
You can also try an anime game launcher
