Hi. Setting up Bazzite for the first time on a Proxmox VM where I will want to pass through the GPU. Therefore I’m trying to set up Sunshine for remote access. When I select “Enable” under “Bazzite Portal > Sunshine”, I’m getting “Failed to set capabilities on file ‘setcap’: Read-only file system”. I get the same thing with ujust setup-sunshine in the terminal.
So then I thought I’d do a ujust update followed by ujust setup-sunshine and it got worse. Now I’m getting:
Service is Not Installed
Disabling any previous Flatpak Sunshine service...
Setting up Homebrew environment...
Cleaning up any existing beta Sunshine install before installing stable...
Error: Refusing to load formula lizardbyte/homebrew/sunshine-beta from untrusted tap lizardbyte/homebrew.
Run `brew trust --formula lizardbyte/homebrew/sunshine-beta` or `brew trust lizardbyte/homebrew` to trust it.
Error: Refusing to load formula lizardbyte/homebrew/sunshine from untrusted tap lizardbyte/homebrew.
Run `brew trust --formula lizardbyte/homebrew/sunshine` or `brew trust lizardbyte/homebrew` to trust it.
[sudo] password for michaelblight:
Failed to set capabilities on file 'setcap': Read-only file system
So I did the brew trust lizardbyte/homebrewand retried and it all seemed to work ok.
However, this all seems very dodgy and more complex than I would have expected. Have I missed the point and gone down some rabbit hole?
