need help with boxbuddy. installed megasync and ran it via terminal but how to export it to ublue?
also, installed variety (wallpaper changer) and i get the following errors:
so once installed on boxbuddy, how to utilize it on ublue without running boxbuddy please?
harold
2
Did the option “Add to Menu” not come up under the “View Applications” section?
Is Megasync a cli app or does it have a gui?
Gui. Got MegaSync to work. But variety’s not working
Plyply
4
Inside your container run sudo dnf install python3-cairo
Just tested it and that fixed the issue.
Thank you sir that worked
yes that helped, new to this so now its running
variety up and running, but no quotes are displayed?
system
Closed
8
This topic was automatically closed 12 hours after the last reply. New replies are no longer allowed.
