I noticed my system hasn’t updated to Plasma 6.3 so I tried to perform a manual update to find this error:
Problem: package Darkly-0.5.15-0.x86_64 from @commandline requires libkdecorations2.so.6()(64bit), but none of the providers can be installed
cannot install both kdecoration-6.2.1-1.fc41.x86_64 from fedora and kdecoration-6.3.0-1.fc41.x86_64 from @System
cannot install both kdecoration-6.2.2-1.fc41.x86_64 from updates-archive and kdecoration-6.3.0-1.fc41.x86_64 from @System
cannot install both kdecoration-6.2.3-1.fc41.x86_64 from updates-archive and kdecoration-6.3.0-1.fc41.x86_64 from @System
cannot install both kdecoration-6.2.4-1.fc41.x86_64 from updates-archive and kdecoration-6.3.0-1.fc41.x86_64 from @System
cannot install both kdecoration-6.2.5-1.fc41.x86_64 from updates-archive and kdecoration-6.3.0-1.fc41.x86_64 from @System
conflicting requests
I’m not sure how to solve it, though. I never installed extra themes, so this came out of the blue. Can anyone help?
If you do have any layered packages, I recommend running rpm-ostree reset, it should clear up any layers and get you back to stock. Then you should be able to update!
thanks, now it tells me Darkly was removed.
I’m still confused, though. I never layered it, and Discover shows it wasn’t installed. Trying to remove it using rpm-ostree resulted in a “there is no package with that name installed, so I can’t remove what’s not there, you ninny!” type of error.
Once again, the system only has flatpaks and I layered only Tailscale following this Troubleshooting :: Fedora Docs so I still have no idea how it got here.
