Monitor connected to USB-C docking station via HDMI not outputting correct resolution
Howdy friends,
First time here and just started using bluefin! So far I really love it, but I am struggling to get my docking station to output for my main monitor.
When I look at the resolution options via xrandr it shows that it is connected on DP-#, but that the resolution is all wrong. Additionally it doesn’t recognize the name or manufacture of the monitor in the Gnome displays settings and mirrors the same resolution settings that xrandr sees.
I have another monitor that connects to the hub over usb-c and it works just fine at full resolution. This one also shows up as a DP-# monitor with xrandr
This whole setup works fine on my windows machine so the hub is functioning correctly.
I tried a bunch of stuff, but am struggling to get any meaningful results.
Obviously I haven’t attached a bunch of logs, but can if that would be helpful.
Anyone had any issues similar to this in the past?
