Missing libGLU.so.1
I’m trying to run a Game, but it won’t start. The error message is
error while loading shared libraries: libGLU.so.1: cannot open shared object file: No such file or directory
So I googeld it and could be installed by this command (although the KI said, that this file should already be installed on Bazzite):
sudo dnf install mesa-libGLU
but that one fails too. Error Message:
ERROR: Fedora Atomic images utilize rpm-ostree instead (and is discouraged to use).
Please, read our documentation
https://docs.bazzite.gg/Installing_and_Managing_Software/
F: Can’t find a11y bus: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ExecFailed: Failed to execute program org.a11y.Bus: Permission denied
[2] Sandbox: CanCreateUserNamespace() clone() failure: EPERM
Gtk-Message: 20:56:39.522: Failed to load module “colorreload-gtk-module”
ATTENTION: default value of option mesa_glthread overridden by environment.
[Parent 2, Main Thread] WARNING: Failed to create DBus proxy for org.a11y.Bus: Fehler beim Aufruf von StartServiceByName für org.a11y.Bus: Failed to execute program org.a11y.Bus: Permission denied
: ‘glib warning’, file /builds/worker/checkouts/gecko/toolkit/xre/nsSigHandlers.cpp:201
** (org.mozilla.firefox:2): WARNING **: 20:56:39.899: Failed to create DBus proxy for org.a11y.Bus: Fehler beim Aufruf von StartServiceByName für org.a11y.Bus: Failed to execute program org.a11y.Bus: Permission denied
What game is it? Have you check the ProtonDB/Lutris pages for any hints?
Also IIRC you can try checking in folders in echo $LD_LIBRARY_PATH to see if the library files are present. If it isn’t, you can try running the game inside a separate environment like a Distrobox (try bazzite-arch) or Steam Flatpak.
It is the game Brideconstructor, the Humble Bundle Version
Hmmm i did not checked Lutis.net, just installed it right within Lutris. I will take a look.
