Machine Learning
Note: We want Bluefin and Aurora to be the best developer environment for AI enthusiasts, help wanted!
Local AI
Ollama allows the running of open-source large language models, such as Llama 3, locally. It bundles model weights, configuration, and data into a single package, defined by a Modelfile, and optimizes setup and configuration details, including GPU usage.
Bluefin-dx supports the installation of Ollama in different ways, for example by using the following ujust commands:
ujust ollamainstalls the CLI-version as a container.ujust ollama-webinstalls Open Web UI & Ollama as a container. During the installation process, there is the choice to install either a GPU or CPU-enabled version. Additionally, installation through Homebrew (brew install ollama) is required.
systemd does not autostart the containers; instead, the user needs to activate the script manually by using systemctl --user start ollama or systemctl --user start ollama-web. The systemd scripts are saved under: ~/.config/containers/systemd. The scripts are:
ollama.container- which starts the CLI under port: 11434ollama-web.container- which starts the Open Web UI under port: 8080 (http://localhost:11434)ollama.network, the network name is set as “ollama”
To cross-check if the containers are launched correctly, you can use podman ps --all.
Running the ollama open-webui
ujust ollama-web will set up ollama with the webui as a service unit in your user space:
- Status:
systemctl status --user ollama-web - Restart:
systemctl restart --user ollama-web
You can also start, stop, and disable and enable the service unit. Open localhost:8080 in your browser, then make yourself an account:
Running ollama
ujust ollama to get started! This will setup an ollama service unit in your user space. Use this one if you just want ollama without the web ui:
- Status:
systemctl status --user ollama - Restart:
Desktop integration
Install alpaca to use a native desktop application.
Se the server as http://localhost:11434 in the settings to connect to your local setup:
Terminal Integration
We recommend using mods to use the provided ollama instance as an interface to your command line:
- Install mods:
brew install mods - Open the config file for mods:
mods --settings - Modify the config file with the model you’ve pulled with ollama:
and then make sure the ollama section in the config file matches the same thing:
Save the file and then try it:
Pytorch
Bluefin and Aurora include a NGC container that includes the latest stable PyTorch from Nvidia on top of Ubuntu LTS. It includes python3, pip3 , pandas, matplotlib, and scikit-learn.
The additional
pippackages are commonly used but not comprehensive. Onlypipis used andmambaorcondaare not currently tested.
Pre-requisites
You must already be using bluefin-dx-nvidia as it’s meant for those GPUs and has nvidia container toolkit support. If you want to test before downloading the larger nvidia container run nvidia-smi
inside a regular Ubuntu box (distrobox create --nvidia -i ubuntu) to check that everything works correctly.
To create the box use the following command. Note that this container is large (20+ GB!):
ujust distrobox-mlbox
To enter the working environment:
distrobox enter mlbox
Then the init-hooks will run once. After which, you should be able to run:
nvidia-smi
To check if GPUs are seen and enter the python repo run:
import torch;torch.cuda.is_available()
Various tests can be run to test a transformers inference or training job, or to git clone a pytorch benchmarks repo and run single or multi gpu commands: E.g. to test multi-gpu setup on two 3090s:
git clone https://github.com/aime-team/pytorch-benchmarks.git
cd pytorch-benchmarks
python3 main.py --num_gpus 2 --compile --model bert-large-uncased --data_name squad --global_batch_size 24
On other operating systems, use this .ini file and run:
distrobox assemble create --file /path/to/your/mlbox.ini
Doc credits: @axelquack
