Linuxbrew missing on fresh ISO install
I just installed the latest and greatest bluefin-dx:latest (nvidia variant) featuring Fedora 41, to a clean drive. After I booted it up, the brew command was nowhere to be found, and /home/linuxbrew/.linuxbrew has no files at all, just three subfolders for Caskroom, Homebrew, and sbin.
I then tried another fresh install of the bazzite-nvidia-gnome:stable variant (i forget the exact naming convention, sorry), and it also didn’t have brew present. But the /home/linuxbrew folder only had a .git subfolder.
Has anyone else experienced this?
Also, I have another machine which was already running bazzite, and when I updated it, brew worked fine.
Can you post an rpm-ostree status of the affected system?
Its pretty basic. I hadn’t done any setup to speak of post-install/first-use wizard.
On this particular machine, I installed bazzite and then tried to switch to bluefin to fix it. Didn’t work. I also did a clean install of bluefin earlier, but I’ve wiped it to put bazzite on there.
❯ rpm-ostree status
State: idle
Deployments:
● ostree-image-signed:docker://ghcr.io/ublue-os/bluefin-dx:latest
                   Digest: sha256:2e96d0a22adc7b15e92abbf9c356e32905d731e2e46d14df231f293091725d1e
                  Version: 41.20241031.0 (2024-10-31T04:44:47Z)
  ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-gnome-nvidia-open:stable
                   Digest: sha256:6dfadff34b2f0ed1b459b240987fda78765a2086ccdf8708e9c0bda7293ad217
                  Version: 41.20241030 (2024-10-31T01:22:09Z)
